Introduction: DIY Pc Cooling Fan
this is an instructable for a pc cooling fan for extra cooling
it doen't involve any pc modding
tools & materials:
soldering iron
epoxy or hot glue
old pc card network/sound/graphics card/etc. that doent work or not used
coumputer fan (the type in old power supplies)
connector to connect fan to power (i used a floppy disc connector)
dremel or band saw
pexiglass or sheet metal or thin plastic
tools & materials:
soldering iron
epoxy or hot glue
dremel or band saw
Step 1: REMOVE
remove card from socket
Step 2: MARK
mark fan and bracket
mark it about .25 in from each edge on fan
then mark the bracket
Step 3: CUT
CUT IT OUT (yayyy power tools)
cut the fan and bracket useing a dremel or band saw
!!!!!!! be very careful and use safety glasses !!!!!!!!
and DO NOT CUT THE FAN BLADES
Step 4: CUT
Cut out a piece of your pexiglass or sheet metal or thin plastic the same size as your fan
Step 5: GLUE
glue the piece of pexiglass or sheet metal or thin plastic to the back of your fan
Step 6: GLUE
place the brackets face down on the table and set the fan on top glue the top one on first and then useing another pc card align them.
make sure that you get the distance right then glue the bottom one on
again DONT GET GLUE ON THE FAN BLADES
Step 7: SOLDER & GLUE
solder your connector on making sure you get the polarity right
then glue the connector on the top of the fan
Step 8: GLUE
i found that if you glue a small strip of plastic on
it will increase performance
Step 9: DONE !!!!!!
you're done now go test it and put it in your pc
