Introduction: DIY Small Motor Pump
About: I'm crazy about inventing new things..... and thanks a lot to instructables website which helped me to share my ideas...
Hello guys !.....
This instructable helps you to build your own motor pump....
this motor works on the principle of centrifugal force....
I have built a small motor pump using a small motor......u can build it by using a big motor too.....
Step 1: Parts Needed....
the most important thing is that you can use any plastic container....any motor...any thing....but it should fulfill the basic requirements of the pump motor.......
parts list.......
1. plastic container (should be in cylindrical shape.........)
2. glue (I used fevitite )
3. pen cap and refill...... (any)
4. plastic sheet (any)
5. motor (any)
thats all guys,..............!
Step 2: Drilling Holes
Take the container drill the holes on the top and bottom ends of the container as shown in the fig....
the hole on the top is used to attach the motor.......
the hole at the bottom end is used as a inlet for water flow.....
Step 3: Attaching Motor
the next step is to attach the motor to the lid of the plastic container as shown in the above image........
you can use any glue like hot gule,fevi quick,fevitite.....etc...
Step 4: Time to Make Fan
take the pen refill and cut a small portion as shown in the first image........
then cut two rectangular pieces of plastic sheet......as shown in pic 2...........
and attach these 3 materials to make the fan .....in such a way that the refill should be between the two rectangular pieces........as shown in the second pic......
you can use glue or you can screw them up......as I did.....
Step 5: Attach Fan to the Motor
as shown in the pic u should attach the fan like that........!
Step 6: Water Outlet
make the hole at the cylindrical side of the container in such a way that the fan should be seen through the hole.....
then attach the pen cap to the container as shown in the pic....using a glue.....!
that all......!
Step 7: Attach Both the Things
Just attach the container's lid to the container as shown above.....
ok
you have built a small pump motor.......!
just watch how its working....................!
you must remember that you need not to build a small motor pump as I did ...........you can use different materials...different techniques to make a new one...
................................. thank you.........................................
If u have any suggestions or comments regarding to this topic plz leave a comment below..... :-)
