Introduction: DIY Stylish Sofa-bed
The purpose of this project is to build a sofa that can be also an emergency bed (quite confortable..) and also act as home theater case.
In my room the shape of furniture was particular, so I adopted the sofa shape to it.
If you are interested, you can view the list of my not-yet-realized ideas on my blog
Step 1: Materials
- 5 pieces of wood (multilayer or MDF), the size of wood depends on the size of the sofa. I used 110 cm x 120cm (43 x 47 inches)
- Screwdriver (better if electric)
- Electric saw
- Lot of screw
- Metal bars to connect wood pieces
- Sheets of paper (better if they are big)
- Tape
- High density Foam (10 cm)
- Low density Foam (3 cm)
- Lot of fabric
- Thin plywood
Step 2: Get the Shape
Put together all the sheets of paper in a big one (using tape).
You will use the sheet to take the shape of your sofa.
Put the big sheet on the ground and press it along the angles so that it fit al the curves and lines of the furniture.
The result should be like the one on the photo (I still store the paper shape)
Step 3: Cut the Wood Pieces
Put the paper shape on wood and with a pencil draw the shape onto the wood.
Then start cutting the wood with the saw. TAKE YOUR TIME, you want this job done well!
If the wood do not fit perfectly try to adjust using the saw and cutting little bits of wood.
Step 4: Add Legs to the Sofa
To build a strong sofa I used a lot of legs cutted out from the 5th piece of wood.
I fixed the legs to the bottom wood with a lot of L shaped metal bars.
Before proceeding I tested that the home theater fit into the central box.
Step 5: Add the Upper Pieces of Wood
Add the upper pieces of woof taking care that they fit very close to the wall and the furniture curves.
From the upper pieces of wood, cut out a square to allow an easy access to the home theater. The hole will be covered by the cutted piece of wood.
TIP: Add strength to the sofa attaching the upper pieces of wood to the legs through the L shaped metal bars. You can also use screws directly (see photo)
Step 6: Add Walls to the Sofa and Do Some Painting
To hide the legs of the sofa, I used a sheet of plywood.
First cut the thin plywood with the same height of the sofa.
Attach the plywood to the center part with 2 screws (as shown in the picture).
Then SLOWLY bend the wood until it touch the corner of the sofa (I take 5 minutes to do it. If you do too quickly the wood can brake)
Attach the plywood to the corner of the sofa with 2 screws.
Repeat the steps for the other part of the sofa.
You can also use remaining parts of the pieces of wood to add a door to your home theater box.
Paint the hometheater box with black paint (better if it's matt) and the plywood with white paint.
I also put some grey fabric on the floor of the home theater box to hide the metal bars.
When the paint is dry you can cover the cutted square with a piece of wood.
TIP: If you must acces inside the sofa you can simply remove 2 screw from the corner
Step 7: Build the Soft Part of the Sofa
Using the paper shape cut out booth high and low density foam. Put together the 2 layer of foam (the low density foam must stay on top because it will give a smoother shape to the sofa).
The same paper shape will also be used to cut out the fabric of the sofa (the fabric shape must be bigger than the paper shape to be easily sewed).
You can stop here. Adding some pillows (from Ikea) the sofa is ready to be used!
If there is remaining fabric, you can try to build your own pillows (I made one big and 2 small)
80 Comments
12 years ago on Introduction
on craftzine :)
blog.craftzine.com/archive/2010/02/how-to_custom_sofa_entertainme.html
12 years ago on Step 7
Aren't all those electrical things dangerous in that wood and fabric?
Reply 6 years ago
neither wood, nor fabric will ground a + charge
Reply 12 years ago on Introduction
i agree, electrical and electronic components inside a wood and fabric enclosure without vents... sounds dangerous... just don't forget to turn it off when not in use..
Electric cables are mainly to transport sound so they will not overheat. The only one that do a lot of heat is the big amplifier.
nah its not dangerous, its not like there are bare hi voltage cables in there, but he probably should have cut some vents so the home theater equipment doesn't overheat and get damaged/keep shutting off though.
6 years ago
Wow! I really like that.
6 years ago
This is the best idea I ever saw......!!!!!!! Thank you for sharing!!! You're awesome!!
Reply 6 years ago
Thanks a lot for your enthusiasm!
7 years ago on Introduction
Superb.. It's hard to find perfect fit shape sofa. I should create that one too.
8 years ago
this is the reason why i love instructables
That's really nice! I just love it. How much did it cost you to build
Looks fantastic!
1 critique though: recievers are notorious for giving off quite a bit of heat and can overheat without proper ventilation. Were there any concerns that this design does not provide adequate ventilation for your equipment?
Indeed I added a fan inside the box tho blow out hot air
Good idea, I was going to say. Better to put a vent than to have to replace the amp or even put out a fire.
11 years ago on Introduction
Any idea on how this could be modified for a regular wall? And is it comfortable? good for the back?
it all depends on the height and density of the foam. I needed to limit the height for other reason but is still comfortable to sleep one night
10 years ago on Introduction
If this was heatetd I would pay 18000 euro!!
For that amount I can open s business :)
