Introduction: DIY Tracing Light Box for Under $20.
Let's face it, store-bought light boxes are expensive. And other DIY light boxes usually require cutting, soldering or some other form of work. This DIY light box requires almost no work at all and costs next to nothing. Intrigued? Here's what you'll need..
-1 clear plastic box/bin: approximately $5-$12 (I used an extra scrapbooking storage container that I had purchased from either Michael's or Jo-Ann's. It's nice because it's flat, thin and relatively large as it's made to hold 12x12 scrapbooking papers. These run about $8-$12 but are often on sale and both stores always have coupons.)
-4 touch lights: ~$4 (I bought 2 for $1 each from the dollar store which did not include batteries and one 2-pack from Walmart for $3.96 which included 8 batteries. Turns out they were the exact same product, so I paid a dollar more for the Walmart one taking into account the battery cost.)
-4 AA batteries for each light = 16 batteries total: $2+ (you can also buy these at the dollar store. I bought an 8-pack of low-drain batteries for $1. It's not like you're powering a car here..)
Step 1: Add the Juice
Open the battery compartments and place 4 AA batteries into each light. Follow the pictures inside the compartment if you need assistance with this step.. Replace the covers when done.
Step 2: Place the Lights Into the Box
Open the clear plastic box and place all 4 lights into the box. Touch each light to turn on.
(Note: on my box there is a small divot in the top of the box that one would have to avoid while tracing. However, the bottom of the box is nice and smooth, so simply flipping the box over before putting in the lights would remedy this situation. If you would like a more permanent light box, small squares of adhesive velcro could be placed on each light and in the bottom of the box. I probably won't be using this very often, so I wanted to be able to take the lights out and use them elsewhere if necessary.)
Step 3: Close the Lid
Close the lid to the box and voila! Your very own cheap, DIY light box. Now you can trace to your heart's content... but don't forget to turn the lights out when you're done.
Make It Glow
52 Comments
9 years ago on Introduction
Wonderful! Now I can make a lightbox as a gift for my sister, who always wants to borrow my expensive lightbox. She'll have what she needs and not need to wreck my expensive tool. Thank you so much! These are inexpensive enough to give to the kids, too! Whee!
Haha, you're very welcome.
OMG !
Absolute Genius !
Just what ive been looking for, an inexpensive way to have a lightbox !!! Voted for you - good luck !!!
Once again - Genius !!!!!!!!!!
Thanks so much! I was surprised at how little it cost and how simple it was as well. If only I had stumbled upon it during my undergrad art years..
3 years ago
In engineering - simple is good. That means - this is brilliant! (No pun intended)
My only suggestion would be to get a piece of Lebanon’s or similar from Home Depot or Lowe’s to place on top as a hard, flat, surface to draw on
You are only limited by the size of your box, and it’s not a “one trick pony” sitting around the house in the way when you’re not using it.
Gonna make one today!
4 years ago
my next project...thanks for the great idea!
5 years ago
Great idea. Your box lid looks to have an indentation which would accommodate a piece of glass cut to size. You can add velcro strips to the glass corners and to the cover so that it wont fall out or off. Glass is inexpensive enough to get a sturdy thickness :)
Reply 4 years ago
White acrylic is relatively inexpensive for this purpose as well, but that starts taking the project away from the true simplicity that makes the current approach awesome.
5 years ago
Add aluminum foil inside for extra brightness?
Reply 5 years ago
Hmm.. might work or you could just buy stronger batteries/lights? Give it a try!
5 years ago
I will do this with a glass cutting board (as suggested) and put a long, thin battery operated LED light we already have into the plastic box. No wiring needed. What a great idea... I can't thank you enough. Wish I had this years ago as an artist when I had no money and finally saved up and bought an expensive light table with a plexiglass top and the first day someone came by and scratched it so badly it was unusable. Never did save up the money to replace the top. Now, years later, I will have a very nice, light and portable light table once again. The circle will be complete!
Reply 5 years ago
Haha, perfect!
5 years ago
Thank you SO much for this great idea! I am a new artist and can't afford the cost of a light box and was so frustrated. Thanks to you I can now get busy on my painting! Brilliant idea!!!!
Reply 5 years ago
You're very welcome!
5 years ago
llove to use with plastic clear mat u can buy them at Dollar Tree for one dollar for 2!
5 years ago
wonderful, clever, resourceful! thanx
5 years ago
Brilliant idea! Thanks so much for sharing. :-)
6 years ago on Introduction
looking to do something like this but I need a top made of glass so I can do etching or cutting with my xacto knife.
Reply 6 years ago
This is what you need. https://m.instructables.com/id/How-to-Make-Your-OWN-professional-arttracing-ligh/
Reply 6 years ago on Introduction
I have also seen really thin, plastic semi-transparent cutting mats for super cheap. I think they're supposed to be used for cutting food, but I would assume they would work for cutting and would allow the light to shine through..
