Introduction: DJI Flamewheel LED Lamp
This project is a work for wing tip lights for DJI Flamewheel.
Used the materials:
- PCB's 1 pcs
- LED 13pcs (3mm TH)
- Resistor (package 0603) 13pcs
You can use the following formula to determine the resistance value.
R=(VCC-Vd)/Id
VCC= Supply Voltage
Vd= LED Voltage
Id= LED Current
Step 1:
Step 2: LED PCB's Production.
Download the GERBER file I shared in the attachment and make the production at a PCB manufacturer. (At this stage, I can offer you www.pcbway.com 10 production price will be 5USD.)
Step 3: Mounting
- Solder SMD materials with soldering iron or hot air.
- In the second stage, solder the LEDs with soldering iron.
Step 4: LED Flasher MOSFET Board for ARDUINO Nano
I have designed the mosfet card for the Arduino Nano to make the LEDs the flash features I want.
6 channel mosfet drive.
- Arduino NANO 1pcs.
- PCB 1pcs.
- DTC114YUA 6pcs.
- BSS84 6pcs.
- 10K 0603 Resistor 6pcs.
- 3x7 RA 2.54mm Header
(You can download the Gerber file from the attachment.)
Step 5:
And Final.
