Introduction: DM Screen
I'm starting to run d&d
campaigns and I wanted to make a screen to hide my rolls and hold my notes. I kept it simple with just three panels about the size of an A4 paper sheet (a central wider panel and two smaller ones on the sides).
I used:
2 mm hardboard (two panels 29x23 cm, one 29x25 cm)
4 small hinges (4x1,5 cm)
All purpose cement
Woodstain (optional, finish look)
Chalkboard paint (optional, finish look)
Tools:
Sandpaper
Dremel 4000
Step 1: Panels
For the panels I chose some hardboard pieces that I had laying around. They were all scratched from being used as cutting boards. I scratched them more with sandpaper to give them an aged look, and I tainted darker with red oak wood stain, with paper towels instead of pencil.
Step 2: Putting All Together
To put all together I carved a space for the hinges in the inside part of the hardboard (one side deeper than the other one, so it can fold over itself), and I glue them with all purpose cement.
Step 3: Front Design
In the frontal
part of the panels I wanted to carve related designs. I chose an icosahedron for one of the side panels and a triquetra for the other one. In the central panel I wanted the D&D logo, which was challenging for my skill level with the dremel. I drew it on paper and taped it over the panel, and then followed the trace with the dremel. All things consider I’m happy with the result.
Step 4: Inside
I painted the inside of the panel with chalkboard paint, not planning on writing on it, I just like the finished look of this paint. The notes are held with paperclips so I can change it in different games.
Step 5: Finished Product
I end up with this screen, I found the size comfortable to hold everything I need, and it gives me an area big enough to use behind the screen. Also, my cat approves.
