Introduction: DNA Origami
Hello! This is my first ever instructable and I am very excited to share this with you! I’ll be teaching you how to make this DNA Origami. It’s really easy so anyone can make it! Let’s get started!
Rectangular paper (any color)
Step 1: Fold Your Paper
Fold your paper in half. You can use any size of paper, but it has to be rectangular. I glued two pieces of paper together so I can have a bigger origami.
Step 2: Fold the Bottom and Top Edges
Fold the bottom and top edges about 1cm or 1/2 inch. Make sure to make the creases sharp.
Step 3: Fold Into Sixteen Parts
First, flatten the fold you made in the previous step. Then, fold the paper into halves, fourths, eighths, and sixteenths. You can look at the pictures if you have a difficult time understanding.
Step 4: Fold Diagonally
Fold the rectangles that you made diagonally. If it starts to curl up don’t worry. That just means that you are closer to finishing the project! This step might seem confusing, so you can use the pictures for help.
Step 5: Fold the Edges
Now you want to refold the edges, but you will fold them in different directions. The one that is on the crease will go up and the other one will go down. The pictures help explain it better.
Step 6: Start Turning the Paper
You want to fold each of the rectangles like this. Since the rectangle is divided into triangles, the triangle that is on the top will look like this. Keep doing this to the rest of the paper. As you are doing this, the paper will slowly turn into a circle. It will look like the picture above when you are done folding.
Step 7: Pull on the Circle
Now pull the circle slowly. It will turn into a spiral. This is a left-handed helix.
Step 8: You’re Done! (Video for Help)
Good job! You’re done making the DNA Origami! I hope you had fun making it! Here is the video from where I learnt this origami! You can watch it if you don’t understand the photos or instructions I gave.
https://youtu.be/pB0FMshudqE
If you enjoyed this instructable, make sure to post it so I can check it out!
