Introduction: Door Chain of Super Mario Bros
My name is Emerson Pedroso, I am creator of the YouTube channel DIY Workshop.
Today's project DIY workshop, we will make a keychain port of Super Mario Bros., if you want to know how it was done follow the images above to see the video explaining in detail the construction:
The Channel DIY Workshop is the right place for those who like to learn how to build and cook creatively and easily sign up to our channel to receive updates of videos that will air every Friday, interspersed between the DIY Workshop and GEEK Cooking .
Contact advertising EXCLUSIVE: oficinadiyroo@gmail.com
Para acessar este tutorial em Português, acesse este link:
http://www.designoteca.com/designs/1556
Step 1:
First, cut the 25mm pvc pipe in 9 pieces of 3 cm each, they will be the seams of each connection, then Serre the back of the flange We are only with the thread, so use as a foundation. Eventually assemble following the images below and the previous slide.
Step 2:
With it already mounted, place it on some support to pass the primer, it served to better fix the ink when dry, pass 2 hands ink green sheet spray.
Step 3:
To make the outputs of pipes, cut a neodymium magnet in 3 parts with cutting pliers and glue each part on a size of circle the pipe (2,4cm), pass hot glue to secure better and allow to dry.
Step 4:
Now go a little hot glue around the magnet, at the very edge of the paper and place inside the pipe output, the space you have to leave it 5mm between the paper and the output, to not be too deep.
Step 5:
Finally, print the cast of characters (at the end of the slide), cut and lap two images, remember to also cut the mirror image to that it is just right when you paste one after another, and finally paste with glue hot a common magnet beneath the character and place in any pipe output.
Step 6: Final Result
Enjoy this Instructable?
Soon we will post more projects in English to accompany you. Let us suggestions and comments for upcoming videos if they want the subtitled video, if you have enough requests I legendo :P Access our channel on youtube, besides workshops have a cooking table :D
https://www.youtube.com/channel/UCI-bK_5XZ7ybCk5u...
Thank you for your personal attention and even more! \ o
