Introduction: DRILLING AND SANDPAPER MACHINE
Make a hand-held drilling machine on your own.This project was made by Prince Dzuckey.
You can e-mail me for more information at Dzuckey@yahoo.com
Step 1: GATHER YOUR MATERIALS AND TOOLS
MATERIALS
(1) motor
(2) wire
(3) switch
(4) 9v battery
(5) a piece of plywood
(6) a piece of PVC pipe
(7) Formica glue
(8) sandpaper
(9) Drill pin
TOOLS
(1) hacksaw
(2) soldering iron
(3) knife
(1) motor
(2) wire
(3) switch
(4) 9v battery
(7) Formica glue
(8) sandpaper
(9) Drill pin
TOOLS
(1) hacksaw
(2) soldering iron
(3) knife
Step 2: CUT PLYWOOD AND SANDPAPER
You have to cut a piece of plywood in the form of circle. Then you have to cut some of the sandpaper in a circle of the same size. Put them on a clean table to avoid dust.
Step 3: CONNECT THE WIRES
You have to connect the motor, the switch, and the 9v battery . After you have finished connecting them, you have to put them inside the pipe.
Step 4: FINISH
You have to put glue on top of the plywood circle and you have to put glue on the sand paper. Put both in the sun for 30minutes. After you have put it in the sun for a long time, you have to go to collect it. When they are dry put them together. Make a little hole in the middle of the plywood, and mount it on the motor shaft.
