Introduction: DS1302 + 1602 LCD Clock
In this project I'm not going to make a clock, I try to experiment DS1302 and 1602 LCD brought recently. I have followed other instructablers but cannot get an expected result, so I tried and tried until it done and publish my project here to share with all.
In my project I have only changed some wiring and software to make it work, so I will concern on the changes.
Step 1: LCD and RTC Wiring Change
This is not much breakthrough in fact any wiring could be worked, but I've found one wire in question caused my LCD no display, so I correct it as follow.
/*LCD Display (1602)
1.VSS to Arduino GND
2.VCC to Arduino 5V
3.VEE to Arduino GND
4.RS to Arduino pin 10
5.R/W to Arduino pin 9
6.E to Arduino pin 8
11.DB4 to Arduino pin 7
12.DB5 to Arduino pin 6
13.DB6 to Arduino pin 5
14.DB7 to Arduino pin 4
15.LED+ to Arduino 5V
16.LED- to Arduino GND*/
/*DS1302 RTC
RST to Arduino 13
DAT to Arduino 12
CLK to Arduino 11*/
Step 2: Software Change
There are nothing wrong in the software found in the web, what my changes are only adopted in my project.
Firstly you have to include the LCD
#include <LiquidCrystal.h>
Secondly amend the RTC and LCD initialization
DS1302 rtc(13,12,11);
LiquidCrystal lcd (10,9,8,7,6,5,4);
Thirdly format the day time string to be printout from LCD
char buf_1[16], buf_2[16];
snprintf(buf_1, sizeof(buf_1), "%s %04d-%02d-%02d", day.c_str(), t.yr, t.mon, t.date, day.c_str());
snprintf(buf_2, sizeof(buf_2), "%02d:%02d:%02d", t.hr, t.min, t.sec);
lcd.setCursor(1, 0);
lcd.print(buf_1);
lcd.setCursor(4, 1);
lcd.print(buf_2);
Step 3: Finally You're Done
A clock may simply tells time, but the code inside have other opportunities to trigger some activities, for examples
day.c_str(),
t.yr,
t.mon,
t.date,
t.hr,
t.min,
t.sec;
