Introduction: DSman195276's Sidearm --updated-- V1.5 Is Here!
well here it is, the long awaited gun. i posted it in a forum but did not have enough battery life left to make the instructable. i finely got some new batteries and because i kept you waiting, i made a new weapon(assault knife to be exact, it is supposed to be used with the DD-27).
well, it works with the same concept as Loosewire; SOE Operative's slide action gun. though this gun does not have a slide it has the "mag in handle" idea.
instead of shooting white rods like loosewire's mine shoots bullet type things, and they work a lot better, if you pull the ram back far enough it never jams.
i hope you like it! please rate!
the third and forth are of the 1.5 version.
Step 1: Barrel
probably the hardest part of the instructable(though still not that hard). just make from the pictures and look at the notes.
Step 2: Handle
this part is semi-easy. just make from the pictures. make sure to read the notes on them.
Step 3: Top Part of Barrel
just make, read any notes there maybe on these pictures.
Step 4: Ram
almost done! this is the easiest thing to make.
Step 5: Put It All Together
very easy! just look at the pictures
i almost forgot the mag pusher. just make that first.
Step 6: Put on Rubberbands, Load and Fire!
just look at the notes.
to fire just put bullets in the mag, pull back the ram so it at least comes to the read connectors then release it. that prevents jamming. then pull the trigger.
