Introduction: Da Vinci XYZ 3D Printer Filament Counter Resetter
One of my XYZ 3D printer cartridges died a couple of days ago :( (so sad) -- the printer was showing 0m left, where there was still filament in the cartridge ... ?!?, so I made this simple cartridge counter resetter that snaps at the bottom and resets the internal eeprom counter. It uses an Arduino Pro Mini PCB, spring-action push pins and a 3v button cell. The code on the Arduino allows you to set the filament length to 240m so it should not bother you for a while.
Step 1: Building the Cartridge Resetter
If you want to make your own, you will need the 3D printed shell published on Thingiverse.com, an Arduino Pro Mini
(either this one or any other compatible depending on how long you want to wait to get it, 3 spring-loaded pins the actual code (you can use the original code on github written by votivo) and the wiring instructions (below). If you can't be bothered getting into programming or having to buy the USB programmer etc, or if you simply dont' have the time, you can get the whole thing (less the 3d printed shell) from me - see below for the magic paypal buy now button.
Step 2: Cutting the Wires
Cutting the wires
This is a guide to help you prepare the 3 needed wires (can be any wire, the thinner the better since there is no much space under the controller). The wires must be insulated and can be of any color. They should be stripped using the below (approximate) lengths (they are not critical, just make sure it all gets wired correctly and fits snugly - there is no much space in there!).
Step 3: Wiring the Controller
Insert the golden pins into the 3 holes in the shell/enclosure, making sure you push them in to their end (they should have a tight fit, if they are loose, try the other shells with different size holes which I published in Thingiverse).
Use the diagram image to wire the Arduino to the 3 golden pins with the shell/enclosure.
The resetter only fits one way (which prevents you from accidently reversing it). The tab always faces the outside (or end) of the filament cartridge.
Step 4: Using the Cassette Filament Resetter
Connect the 3V battery into the battery slot (the power light on the Arduino will come on and the programming light will start flashing – if not, check the wires and make sure they connect to the battery properly, also, make sure that the battery is inserted correctly. The negative of the battery should face the outside of the shell/enclosure and the positive towards the Arduino). Position the resetter as per the pictures below (Fig 1, Fig 2), press on it and wait 2 seconds, the flashing light will stop flashing and go solid for about 2 seconds. Once programming is complete, it will turn off. At this point you can remove the programmer from the cartridge and disengage the battery – do not leave the battery plugged into the programmer or it will drain. If needed, please visit wctek.com/shop and take a look at the video on that page …
53 Comments
2 years ago
i know this Instructable is pretty old and technology has changed so if anyone still needs to reset their spool, PM me and i can do it much simpler
Reply 7 months ago
I would greatly appreciate the updated, simplified instructions.
Reply 8 months ago
Hi I need to reset a Da Vinci 1.0A
Reply 8 months ago
Hi,
I'm struggling with the counter from my Davinci jr 2.0 I can't reset it. Nothing works is there a way to make it work. Thanks in advance Best regards
6 years ago
Hi, does it works with PVA material?
6 years ago
Hi,
Thanks for your excellent instructable, it's nice to see one so well written.
After seeing so many positive comments saying everything worked perfectly for some users, I wonder what I'm doing wrong with my attempt.
I have an arduino Mega 2560 , with the eeprom card connected to 5v, Gnd and digital pin 7 (I've even soldered the leads directly to the EEPROM board, just to make sure we have good connection), but all I get back in the Serial Monitor is :
'Testing connection to Da Vinci EEPROM CHIP'
Can you suggest what I might be doing wrong? Is it OK to use a Mega rather than a pro mini?
Any thoughts you have would be most appreciated - the outrageous cost of the XYZ filament is sending me broke!
Thanks in advance.
6 years ago
I do not see a buy now button,
6 years ago
Has anyone tried this on the new firmware AIO 1.2.2?
Reply 6 years ago
hi JenDoll15...did you tested it on 1.2.2?
6 years ago
may i know whether it can work with firmware 2.1.2?
7 years ago
Thank you. It actually worked. but temperature is too high reading 220 instead of 210. it did print yet it burned the filament. how to adjust the temperature.Bed tempreature was 90 that was fine. any help. thanks
7 years ago
I am giving this a try with an arduino uno R3 and I get the error below:
Filament_98C:78: error: 'volatileboolean' does not name a type
static boolean read_bus(void) {
Using the github link above and copy/paste the sketch to the arduino program. I tried with the cartridge chip attached and disconnected and get the same errors. There is plenty more to the error message, but I figured I would just put the quick sample here. I am pretty new to the arduino and tried to google my way out of this to no end. Any help is much appreciated.
Reply 7 years ago
I had this same error with version 1.6.6 of the Arduino IDE. Try downgrading to version 1.5.8 or lower. After doing so it compiled for me with no problem. When using this ensure your correct COM port is selected and turn on the Serial monitor (under tools-serial monitor or by pressing Ctrl-Shift-M) with a baud rate of 115200 so you can see the program's messages. Look for a success message after it writes the new EPROM contents.
Reply 7 years ago
After a few tries, SUCCESS!!! Of course now the AIO is showing "Unidentified" in the cartridge status, but I will probably have to do some rollbacks on that firmware to see whats up. I am testing all this with the printer disconnected to the PC before I tackle the xyzWare stuff since that will probably have to go back a few revisions too. Thanks again for the help.
Reply 7 years ago
I will give this a try, thanks for the assistance.
7 years ago
Which Battery to use? CR2032 maybe
7 years ago
I have a new da Vinci jr arriving tomorrow. So question will this trick work with off brand pla? Sorry new to this whole thing. Trying to bypass xyz limitations.
Reply 7 years ago
wctek will release a new resetter by tomorrow specifically for the davinci 1.1 Plus -- I am not sure about the JR (or if it is the same type of printer- or if it can be resetted etc).
8 years ago on Introduction
When I put a cartridge in that has been reset it takes forever for the bed to heat up and the extruder does not heat up at all. Everything works fine if I use a cartridge that has not been reset.
My printer is now saying that my cartridge isn't genuine
