Introduction: Darn Yarn Hat!
This is my very first Instructable. I am 11 years old. I am using my Dad's account. I hope you enjoy. :-)
P.S.
This CHADOVISION approved. This my daughters very first Instructable. She saw how much fun I have had doing them she want to do some too. I am actually very happy/proud how this came out.
Step 1: Materials
This hat is what my Instructable is about. This is what you will need
Loom
2 colours of yarn ( I make the pompoms out of a thinner yarn then the rest of the hat.)
Scissors
Needle
Step 2: Getting Started
To cast on you wrap the yarn around the loom like this. You do that all the way around the loom. Do that twice. It will look something like this.
Step 3: Next Steps
You stick the needle in the bottom loop and lift it over the peg. Keep doing this all around the loom. The inside looks like this.
Step 4: Repeat
Just repeat steps 1 - 2 over and over wrap string around peg stick needle in bottom loop then lift that loop over the peg
Step 5: Keep Going We Are Getting There
Like before keep doing the three easy steps, wrap string around peg, stick needle in bottom loop, and lift over the peg you can count the number of rows by theses little stitches right now you should have 15-16 rows.
Step 6: Next Steps
Once you get to 20 rows you can stop using the three steps and move on to the next three steps
Step 7: Lifting Off the Loom
The next three steps of my hat are, stick the needle in the loop, pull the string all the way through the loop, then you lift the loop off the peg.
Step 8: Sewing
You sew it up with the needle going in out over the string.
Step 9: Pompom Maker
You cut a 38 cm ( 15 inch )piece of string from the thinner ball of yarn as in the black and white ball of yarn I am using in step #1. Put it in the pompom maker as I am in the first photo.
Step 10: Pompom 2
Place the second pompom maker under the first one. Like in the first photo. Cut a 19 foot long piece of the black and white string.
Step 11: Wrap Your Pompom
Take the 19 foot piece of string and wrap it around both of the pompom makers until you have no more string to wrap around . Just tuck the ends in with the rest of the string for now.
Step 12: Double Knot
Tie a tight double knot with the two ends then grab your scissors and get ready to cut.
Step 13: Cut the Knot
Cut all of the strings in half like in photo # 2 , then cut the rest of the strings in half.
Step 14: Getting Close to the End
Once all of the strings are cut in half your pompom will look something like this one.
Step 15: Tie on Your Pompom
Turn you hat inside out and pull two piece of yarn through and tie off your pompom from the inside then turn your hat right side out. Now repeat steps 9 - 15 one more time.
Step 16: Double Check Your Work
Make sure that the pompoms are tied on both sides then turn right side out and...
Step 17: The Finished Product
You now have a cool homemade hat!!!!!!!!!!!
