Data Safe
Intro: Data Safe
The fastest and possible most secure back-up drive. Take one safe, one UPS, a gigabit NAS enclosure with a RAID 1 configuration and there you have it.
Fast with minimum security risk, protected in case of fire and instantly accessible. I've got an uptime of 136 days and counting with no overheating and gigabit rates, with all that your data can just live safely on the network.
Another option if backing up over the net doesn't fit your needs.
9 Comments
dvdweide 13 years ago
I also own a data safe, and would be interested in a solution like this.
But are you sure you don't have heath problems?
I mean, did you hang a thermometer in there to check out?
Did you measure the power consumption of the NAS device inside?
I ask this because my safe is really REALLY very well isolated. After all, that's the main scope of a data safe, isn't it?
From the picture it seems that your safe is somewhat less isolated than mine, but it may be bigger than i think. Mine has 10cm of isolation on all sides.
turboboost17 8 years ago
It's been 6 years and I've had up times of over 500 days, no thermal shutdowns, no drive failures. Wooohoo! :)
turboboost17 11 years ago
What helps is that the NAS power supply is OUTSIDE the safe, so the only heat is from the CPU and drives themselves.
I recently upgraded to two 3TB drive in RAID 1, I hope this crash plan lasts another 5 or 10 years.
muddog15 10 years ago
I would consider in the future working out some kind of Water cooling heat sink that covers all sides of the safe "Except the door" to where you can put a thermometer to turn on the pump at about 50 Celcius.
tinker234 12 years ago
Even with all that I'm looking into off-site back-up because even all that could fail.
I might just back-up to CD-R gold as permanent archive for pictures, that's the only digital format on the planet that can last 400 years without corruption.
mightywombat 13 years ago
turboboost17 13 years ago
This safe isn’t even bolted to the ground, because I’m using those holes to run the cables, so there’s no real deterrent, you could just walk out with it.
Thanks for the heads up.
