Introduction: Date Caramel
About: Hello and Welcome to In the Kitchen With Matt. I am your host Matt Taylor. My goal for the show is to teach you how to cook really good food at home for cheap. Eating out everyday can get expensive, but it doe…
In this Instructable, I will show you how to make caramel with dates. This easy healthy caramel substitute recipe is amazing! It is pretty crazy how close pureed dates taste to real caramel. There are obviously texture differences, and this is thicker, but it is so good and a great substitute for people who would like to be healthier, but also still want a bit of sweetness in their life, haha. If I can do it, you can do it. Let's get started!
Don't forget to follow me and check out my other Instructables. :)
Follow the easy steps below or watch the video tutorial, or do both!
Step 1: Ingredients and Tools
Ingredients:
  • 2 cups of pitted dates, roughly chopped (Deglet Noor, Medjool Barhi, etc.)(175g)
  • 2 Tbsp of coconut oil, or use vegetable, olive, etc. (30ml)
  • 1/8th tsp of salt (less than 1 g)
  • 3 Tbsp to 1/2 cup hot water (45ml to 120ml)
*Note: These ingredients don't have to be exact, you may need more oil, more or less water, etc. Or maybe you want to add a bit more salt.
Tools:
  • Food processor
  • Spatula
  • Knife
Step 2: Blend Up Those Dates
This recipe is super easy. But it may take a little time depending on the type of dates you are using. Some dates are naturally softer than others and blend up easier in the food processor without help.
Add the dates to the food processor, along with half of the oil to start. Then add in the salt. And blend!
Now if the dates just move and shake around inside the food processor and are not breaking up, then you will need to do the next step, which is common, so don't worry about it if it happens. Or you can start with the next step first.
Step 3: Cut Up the Dates
Add the dates to a cutting board and cut them into chunks, then add them to the food processor along with the salt and oil then blend.
NOTE: You can also soak them in water for 10 to 15 minutes or longer to soften them up before trying to blend them. Just drain them before putting them in the food processor.
Step 4: Water, Blend, Scrape
Now add hot water a little at a time to get the consistency that you want. Use a spatula to scrape the sides of the bowl once or twice. Then blend again, etc. Until you have a thick or thin date caramel.
It is really that easy, no cooking, no candy thermometers, etc.
Step 5: Serve Them!
You can use the date caramel however you like. I love dipping tart Granny Smith apples in it. Enjoy!
It will make 8 to 10 servings.
You can print the recipe here if you like.
Step 6: Video Tutorial
Now watch those steps in action with this video tutorial. :)
