Introduction: DeLonghi Primadonna XS Steam Valve Cleanup
DeLonghi Primadonna XS steam valve cleanup
I have hard water and even descaling each two weeks (much more often than the machine requests) does not help preventing limescale build up.
When some limescale breaks up (due to expanding/shrinking of boiler during heat-up/cool-down) it goes through all piping and eventually stops at steam valve disrupting steam stop – You may see/hear it when You use milk frother and after milk cycle the steam still flows.
The procedure of cleaning the valve is quite simple and fast and may save You time and money getting the machine to service.
I strongly recommend to clean the valve at first symptoms of problems because otherwise it may get destroyed (see further) and need to be replaced.
BEFORE WORK COOL THE MACHINE DOWN FEW HOURS.
Please note that nearly all screws are the same except one little longer for upper cover.
Philips #1 screwdriver
Torx #9 screwdriver
long nose pliers.
Step 1: Open the Machine
Open the machine as shown on this movie: https://www.youtube.com/watch?v=ciAgZ898GF4
The valve is located in mid of upper part of machinery
Step 2: Unscrew (1 Screw) of Heater Cover
Step 3: Take Off Heater Cover
Rotate cover slighly counterclockwise becasue it has a litte hook/notch on the left – please hook it back when reassembling (pic.7)
Then pull it forward, down and to You
Step 4: Detach Grounding Cables From Cup Tray
Step 5: Detach Water Pipe
Detach water pipe in heat shield pulling it up.
At reassembly carefully push it back.
Step 6: Unscrew Boiler 2 Screws
Step 7: Unscrew Upper Cover (longer Screw - Do Not Mix With Other)
Step 8: Free Small Pipes
Pull gently small pipes out of their hook
Step 9: Now You Can Pull (tilt) Complete Boiler Assembly With Two Hands – Do Not Use Force.
Step 10: Unscrew Valve Solenoid (body)
Detach three faston terminals from valve solenoid
Detach water piper from valve top inlet
Unscrew two small Torx screws on both sides of valve
Pull up valve body. The valve piston inside is lose – may fall out of body.
Step 11: Cleanup
Now You can see limescale residues/stones inside the valve and – more important – on piston rubber head. This is the reason for valve not working properly.
Remove carefully all residues from valve chamber and rubber head.
Step 12: What Happens If You Do NOT Clean It Up Soon...
If You let the stones to stay to long in the valve it may destroy the rubber head and valve will never again work properly.
Step 13: Reassemble in Reverse Order
Whole procedure takes approx 30 minutes at first disassembly and ca 10 minutes on next one.
1 Person Made This Project!
- mfmdds made it!
4 Comments
8 months ago
Thanks for sharing this! You saved our cappuccino! And an expensive repair.
1 year ago
Thanks for this tip. Saved me $400 quoted for a repair!!
2 years ago
Hey GrzegorzR5
A quick post to thank you for posting the video and instructions about the problem with the Dehlonghi machine above. My lady took ours to the repair shop and they said 4 weeks and very expensive.
So, I found your post and followed it to the letter and found the crud and damaged solenoid rubber. I resurfaced the rubber tip using 600 grit Wet & Dry paper. Now the machine makes coffee like a new one!!!
So thanks from Down Under
Gerard
3 years ago
Thanks for sharing your tips!
