Introduction: Deathstroke Mask
Thank you for checking out my first instructables! if you have any questions comments or concerns let me know
Items you'll need
Iron man mask
Masking tape(lol mask-ing tape)
Black spray paint
Orange clay
Sand paper
Items you'll need
Iron man mask
Black spray paint
Orange clay
Sand paper
Step 1: Sand Iron Man Mask
Any type of sandpaper will do. Sanding the mask will help the clay stick to the surface
Step 2: Apply Clay
I purchased clay from AC Moore for this step. The purpose is to cover all of the grooves in the iron man mask so it is smooth. I just went a little overboard It took me a few days to cover the whole mask and smooth out all of the clay. Make sure you give the clay time to dry before applying the next amount on top of it if you choose to do so
Step 3: More Clay
This was the trickiest part for this step reinforce the inside of the mask's right eye (left if you're looking at it) with tape... A lot of tape then apply the clay to the front of the mask be gentle and the tape should hold apply clay until the eye hole is no longer visible
Step 4: Taping
Tape the right side of the mask to the center of the mask start from the center strip of tape and center the tape as best as you can. After the first strip is done work your way out towards the edges of the right side of the mask Don't leave any creases or the paint will get in also just a word of advice tape around to the back of the mask so while your spray painting none of the spray paint gets on the inside of the mask
Step 5: Spraypaint
Leave the tape on and spray the untapped side of the mask with a few coats of spray paint and boom deathstroke
Step 6:
Thanks again for checking out my project!!!!
