Introduction: Deck Box
This is a deck box for some cards with a little extra room for some small dice. It should work with any cards. Bicycle, MTG, whatever. It has a screw on top that is pretty sturdy when screwed together.
Designed in TinkerCAD and printed with Repetier host. I used a crappier printer than most to print this so if you have something like a creality it should print fine. no supports needed. Hope you like it.
3D printer and some PLA filament.
Step 1: Download the File
Go over to thingiverse and download the file.
https://www.thingiverse.com/thing:4890589
If you would like to, you can use something like blender or tinkercad or fusion360 to edit the file.
Step 2: Print It.
Open up your printing program. I used Repetier but Cura or something similar should work just as good.
Print settings I used:
Layer Height: 0.2 mm
Infill: 15% (recommended to print with higher infill 20-30% if you want the deck box to be drop proof)
Supports/Rafts: supports aren't necessary and would probably mess the threads up if you tried to print with them. they aren't recommended. A brim or raft is your choice. I didn't use one though.
Click PRINT!
Step 3: Enjoy Your New Deck Box!
Take it to a card shop or show your friends.
