Introduction: Decorated Wall Lamp
Build and decorate your own wall lamp.
It's cheep, it's easy, and it's fun!
Step 1: Electricity - Materials and Instructions
I bought the parts and put it together by myself.
You can actually use a ready made lamp and skip this part.
Materials
1. Electrical cord + plug + switch
2. Contact mount
3. Swivel
4. Master socket
5. Nipple
6. Washer
7. Dual socket
8. Wall mount
Instructions
A. Connect the Nipple (#5) into the Swivel (#3)
B. Screw the Washer (#6) onto the Nipple (#5)
C. Insert the thin end of the Electrical cord (#1) into the Nipple (#5)
D. Connect the cord to Contact mount (#2)
E. Connect the Master socket (#4) to the Swivel (#3)
F. Connect the Dual socket (#7) to the Master socket (#4)
G. Connect Wall mount (#8) to wall
H. Insert Nipple (#5) into position on the wall mount
I. Tighten washer
Materials
2. Contact mount
3. Swivel
4. Master socket
5. Nipple
6. Washer
7. Dual socket
8. Wall mount
Instructions
I. Tighten washer
Step 2: Plastic Cover - Materials
Step 3: Make a Stencil
I cut my stencil in a laser cuter but you can use this instructable: Photograph to Stencil
to create any pattern or design you want.
Step 4: Paint Your Design
1. Tight the stencil to the plastic plate. ( Use your fingers to secure the stencil in itââ¬â¢s place)
2. Spray a few layers of paint on the plastic plate depends on the type of the spray, color and desired transparency. (Let dry between layers).
Step 5: Hang on the Wall
1. To hang the plastic on the wall, you will need:
3. Put plastic on the wall and mark with a pencil the exact location of the holes.
4. Drill 4 holes in the wall. Put plastic anchor.
5. Insert Screw through plastic - pipe - wall.
- 4 Pipes - Their length is the length in which you want the lamp to be away from the wall
- 4 Screws - Pipes Length + Plastic depth + length of anchor.
