Introduction: Decorative Lion for Baby in Wool
Esta es una hermosa técnica en lana y cordel, ideal para decorar la habitación de tu bebé, esta vez elegí el león, pero realmente con esta técnica puedes hacer cualquier animal, como un pingüino, un elefante o tu personaje animado favorito, solo Tú debes tener el deseo y eso sera todo.
materiales
lana de colores, negro, blanco, marron algodon silicona
cordón alambre dulce pinzas metro tijeras
Step 1:
To start with the help of a meter, measure 8 strings of cotton cord and cut them to the following measurements:
1 line -rope is 49 cm - coffee
2 line-rope is 46 cm- coffee
3 line-rope is 43 cm - coffee
4 line-rope is 41 cm- coffee
5 line-rope is 37 cm - coffee
6 line-rope is 34 cm- white
7 line-rope is 31cm- white
8 line-rope is 28 cm- white
Step 2:
take the cotton strings, leave 3 cm at each end of the strings.
then to wrap the cotton ropes with colored wool, I started with the white wool ones.
Leaving the 3 cm, a knot will be made with the wool and begin to roll up until the end at the other end, leaving the 3 cm at the end of the rope.
Step 3:
1. Then cut two strips of cord 12 cm long, which will be used. to form the ears.
2. In the same way, a piece of sweet wire will be cut,
3. glue the wire to the cord with hot silicone, this will make it more firm and the ears can be molded.
4. With brown wool wrap the cotton rope.
Step 4:
1. Glue each strip of string with silicone and begin to form a kind of rainbow, glue the first 5 lines of brown string.
2. Paste the 3 lines of white wool rope.
do not join yet as you need to make the nose.
Step 5:
1. With the help of a pencil mark the nose of the lion on the 3 lines of white wool rope, this will serve as a guide.
2. With silicone wrap black wool on the guide that was made with the pencil.
3. Now if you join the 5 brown strings with the 3 white strings.
Step 6:
Trim the ends of the ropes, comb and cut the excess with the help of scissors.
Step 7:
With silicone glue the fringed curtain tape around the edge, this will give us the appearance of the lion's mane.
Step 8:
1.To finish, cut two small strips of black wool, to form the eyes.
2.With silicone paste the eyes and ears of our lion.
Step 9:
