Introduction: Decorative Picture and Paper Hanger
I created a decorative picture and paper holder. I wanted a cute place to hang my photos and to-do lists. So I made this to solve that problem.
Tools and Materials Needed:
- Saw
- Pencil
- Sandpaper
- Small Sawtooth Picture Hangers
- 2 1” Nails
- 6 1” Screws
- Hammer
- Tape Measure
- Drill
- Sanding Sponge
- 1 Black Clip
- 4 Decorative Screw Fasteners
- Super Glue
- 1 1x4 21” long piece of wood cut into 3 equal lengths
- 1/2” piece of plywood cut into 2 pieces that is 1” wide by 7” long
- Same piece of plywood cut into 2” long by 1” wide
Step 1: Measure and Cut
- Measure both pieces of wood to appropriate length.
- 1x4 21” long piece of wood cut into 3 equal lengths.
- Mark measurements with pencil. (Cut straight across with a straight line.)
- Cut all pieces of wood with saw.
Step 2: Sand Wood
- Grab wood you just cut and sanding sponge.
- Place wood on table and sand.
- Make sure all sides are sanded down evenly.
Step 3: Attach the Picture Hanger
- Grab one piece of your 21” long piece of wood that was cut into 3 equal pieces.
- Grab your plywood that was cut into 2” long by 1” wide.
- Grab your small sawtooth picture hanger and two 1” long nails.
- Grab your hammer.
- Line up your piece of plywood in the middle of the wood.
- Then place your small sawtooth picture hanger on the small piece of plywood.
- Hammer in the two 1” long nails into the piece of plywood and piece of wood.
Step 4: Attach Plywood
- Grab all 3 equally cut pieces from the long piece of wood (1x4 21” long)
- Line them up equally spread apart on your table.
- Make sure the piece of wood with the sawtooth picture hanger is at the top.
- Line up your 1/2” piece of plywood cut into 2 pieces that is 1” wide by 7” long on both sides of the 3 pieces of wood.
- Grab your pencil and draw three dots lined up in the center of each piece of wood on the plywood.
- Then grab your drill and drill in holes on each of these dots.
- After drilling in each hole grab your drill to screw in your six 1” screws.
Step 5: Attach Decor and Clip
- Attach the 4 decorative screw fasteners to each corner of the wooden piece by super glue.
- Then attach 1 black clip to the center of the wooden piece at the very top with super glue.
Step 6: Decorating
After adding the clip and decorative screw fasteners you can put in your own to-do list in the clip or picture then hang it up on a wall or anywhere you want.
