Introduction: Decoupage - Our Lady of Guadalupe
Decoupage has its origin in the French word "découper", which means to cut out. It consists of decorating surfaces (of all kinds, from ceramic, wood, cardboard and even soaps or candles) with cut-out paper or fabric images that are fixed to the surface that you want to decorate with a Glue. The final result has to be very similar to as if we had done it with paint and a brush.
Plaster figure of our lady of Guadalupe
Printed napkin
Glue or Mod Podge
Brushes
Grip 180
Carving tools
Liquid gilding gold
White acrylic paint, rose gold
pearl yellow acrylic paint
Step 1: Our Lady of Guadalupe
Having a blessed virgin at home or in this case Our Lady of Guadalupe is something traditional in some homes of Latin American families, especially this religious figure is very traditional in Mexico.
For many devotees, Our Lady of Guadalupe is Miraculous, protector, helps the sick among other prayers
Step 2: Sanding and Carve
Often the plaster figures come with some imperfect, so we need to sand gently until the surface is smoother, then carve, to highlight some parts to give a better finish
Step 3: Apply White Acrylic Paint
When the figure of Our Lady of Guadalupe is completely sanded, we proceed to shake off the excess dust, when it is ready to apply two or three layers of white acrylic paint, this step will seal the plaster and give it a layer of protection.
Let dry for 10 minutes
Step 4: Apply Pearl Yellow Acrylic
Apply two or three layers of pearl yellow acrylic, this color is really beautiful and subtle, this type of acrylic gives different all depending on the angle of light
Step 5: Remove the Two Layers of Printed Decoupage Napkins
For this project I chose a decoupage napkin stamped with pink flowers.
The napkin has 3 layers, very carefully remove the first two white layers and leave the layer that has the pattern.
Step 6: Start Decorating With the Napkin
Once the Napkin is chosen and it is ready without the two layers, apply the glue to the entire back of Our Lady of Guadalupe with a flat brush.
Note: if the glue is too thick, reduce it with water to obtain a light glue.
Let it dry for approximately 3 minutes so it will be easier to place the napkin and be able to start molding it on the figure.
I wanted the napkin to cover the whole back so I put half of the napkin and started to gently mold it with a brush putting more glue on top of the napkin, this is how we seal the napkin
Remove the leftover Napkin
Step 7: Rip the Napkin and Start Decorating
For the front we will begin to tear the decoupage napkin with our hands, this will make the edges irregular and it will look more natural when gluing the napkin
Note: it could be done with scissors but to my liking it is better to tear it with our hands
When some pieces of Napkin have been chosen for decoupage, we begin to apply Glue in the parts where we will put the napkin, this will be to our liking, let it dry for 5 minutes
place the napkin and apply more glue on top, gently with a brush to accommodate the napkin, I chose to also cover the entire front part.
This part of Our Lady of Guadalupe represents rays that surround her in the shape of a halo or aura. She means that she is the Mother of Light.
Finishing this process with the napkin we must let it dry for 8 hours since it is very delicate and breaks easily
Step 8: Apply the Liquid Gilding Gold
Apply the golden liquid gold on the edge of the mantle, on the bow, on the wings of the angel, on the base of the virgin, and some brushstrokes on the part of the dress, all this is optional, since if you want you can place the gold liquid gold where you like it.
Step 9: Decorate the Candle
Decoupage can be made of various materials: ceramic, wood, porcelain, metal, glass, cardboard and even materials such as soaps or candles.
I chose a candle and decorated it with the decoupage napkin, in the same way that I did with the plaster figure, since I want the candle to match the one with the blessed virgin.
Step 10:
Decoupage is a really beautiful, cheap and easy technique, it leaves a special finish to our projects imitating hand painted.
This technique applied to religious images such as Our Lady of Guadalupe makes it look modern and with a delicate touch, this project is a perfect gift for our grandmothers and mothers since many of them are very devout.
