Introduction: Deer Antler Key Chain
VOTING GREATLY APPRECIATED
I bought a new dremel 3000 and had extra deer antler. Also my key chain just broke all tools used came with my dremel tool a lot of the things I did to my antler tine are optional you can use your imagination but ill take you through the process on mine
Step 1: Antler
Find ,buy , or somehow obtain an antler it can be deer,elk,moose it does not matter. I used whitetail deer antler from a buck I took last fall .
Step 2: Own a Dremel Tool
You can use a dremel like I did or some other tool that most of you already have
Step 3: Cutter
This is what I used for cutting antler (it has a. Verry interesting smell while cutting I wouldn't suggest breathing it in ) find a piece you like on it and start to cut it off
Step 4: Engraver
I did some engraving on mine you don't have to but I also used my engraver as a drill for the hole to put the leather in for the keychain part
Step 5: Sanding
I did a small amount of sanding at the top of my keychain right where the keys go
Step 6: Leather
I used leather to hold the keys on the antler just use a drill or if your like me and don't own one use an engraver tip then run the leather through the hole and tie a knot after you add the keys
Step 7: PICTURES
P.s. also can make for a good poker and scratcher
P.s.s also my first instructable :)
