Introduction: Description
I made this mousetrap car because I wanted to have fun with science and see what a mousetrap can do instead of trapping rats. I discovered something called the mousetrap car, and i thought,"Lets see how this car works". So I made it on my own getting materials and having trouble with it till I got it right. I found out how the mousetrap works on the wheels and how it's pretty much the engine. Science is really amazing.
Step 1: Materials
Four CDs or a type of disc, 1 mousetrap, 2 bbq skewers, 1 pair of scissors, 1 glue gun, 2 pieces of 12-15 inch cardboard, paper (any color), at least 2 straws, 1 box cutter, 1 construction mat for box cutting to be safe, and 1 13-15 inch of string
Step 2: Cardboard/Car Body
You will need to glue the two cardboards together on top of each other and you will use the box cutter for this and a construction mat for safety. Then you will cut out the top middle of the cardboard and cut out a rectangle, you will cut 1 inch of the top and bottom of the rectangle and 3 inches of the left and right of it. Also you will do the same for the bottom wheels, the difference is that you will cut the edges instead of in the middle of the cardboard. So you will cut the same measurements but you are cutting the bottom edges of the cardboard for the wheels.
Step 3: Wheel Holders/Straw
Step 4: Attaching Wheels
Step 5: Mousetrap
Step 6: Conclusion
This mousetrap car was an amazing creation and it showed how science once again strikes. I always liked science and hated the struggle but at the end it was worth a discovery. What this mousetrap car showed me was that mousetraps can’t just trap rats, they can also launch energy as a vehicle and make it another step to the future and life. (Forgot to mention that you can decorate your mousetrap in your own way)
