Introduction: Desert Railroad Temperature Detector & Passenger Counter
Purpose:
Temperature: This instructable will teach you how to set up and program an Arduino RedBoard (using MATLAB) to detect the temperature of a railroad. When an unsafe temperature for the passengers is reached, a warning message sounds, buzzers go off, and a warning sign lights up .
Passenger Counter: This portion will teach you how to use a button in order to count passengers and sound a warning when max capacity has been reached.
Features:
- Uses Button to count up passengers entering train
- Uses TMP36 (temperature sensor) to detect the temperature of the railroad
- Uses an Red LED light to warn the train station
- Uses buzzers to sound alarm
- Sends an alert email with a plot of temperature vs time
- Pop-up warning messages on MATLAB
Step 1: Materials and Supplies
- 1 Laptop
- MATLAB 2017
- Download Arduino Toolbox
- Sparkfun RedBoard
- 1 Power Cable
- Breadbord
- 14 wires
- 1 Piezo Buzzer
- 1 Push Button
- 2 10k ohm resistors
- 1 TMP36 sensor
- Red LED light
- 3D printed sign (optional)
Step 2: Board Setup
Follow the setup above
Step 3: Writing the Code
While Loop: To ensure the code continues to test the temperature and sense the button status (pressed or unpressed), we place the code in the while loop for a specified time period.
Using TMP36: We determine the temperature by reading the voltage and converting it to degrees Fahrenheit, using conversion factors. Then, we use an if statement to play a tone and sound/send alerts if the temp is greater than or equal to the set max temperature
Using Button: With an if statement, we can test if the button was pressed using readDigitalPin. This command will return a Boolean (1 or 0). If the response is 0, then the button was pressed and the counter of passengers increases and displays a welcome message. Then, when the max capacity is reached, a warning message is sounded.
Step 4: Copy the Code
%Inputs: Pushing the button, temperature sensor
%Outputs: lights, buzzers, audio alert, emails, graphs
%Purpose: This product is designed to help ensure the safety and comfort of %passengers traveling by train through the desert.
%Usage: Detecting the number of the passengers using a push button, and %detecting the heat using a temperature sensor and graph it and sends both %passengers numbers and the temperature graph to the train station
configurePin(a, 'D2', 'pullup'); %in future releases use configurePin
time = 200;
e=0;
x=0
while time > 0
button_status = readDigitalPin(a, 'D2'); % equals zero when button is pushed, otherwise equals 1
voltage = readVoltage(a,'A0');%pin depends on where we place it
tempCelcius = (voltage*100)-50; %given in sensor manual
tempF(time) = (tempCelcius*1.8)+32 %known conversion formula
max = 120; %degrees F
writeDigitalPin(a,'D11',1);
rem=mod(e,2);
if tempF(time)>=max
writeDigitalPin(a,'D11',0);
writeDigitalPin(a, 'D9', 1);
playTone(a,'D9',2400,.5)
pause(.5)
writeDigitalPin(a,'D6',1)
playTone(a,'D6',1000,.5)
pause(.5)
pause(.5)
playTone(a,'D6',1000,.5) %plays "siren"
z='Overheat.m4a'; %This puts the sound file into a variable
[data,freq]=audioread(z); %Loads data from sound file
o=audioplayer(data,freq); %Creates an object to control the playing of the audio file
o.play() %Plays audio file
o.playblocking() %Plays file and waits for it to finish
end
if button_status == 0 && rem==0
e=e+1
msgbox('Welcome Aboard!');
elseif button_status == 0 && rem==1
e=e+1
msgbox('Bienvenido a bordo!');
end
if e==5
if x==0
playTone(a, 'D6', 600, 1);
s='Warning_EF.m4a'; %This puts the sound file into a variable
[data,freq]=audioread(s); %Loads data from sound file
% o.play() %Plays audio file
msgbox('Max Capacity')
x=x+1
end
elseif e>=6
playTone(a, 'D6', 2400, 0);
end
time = time - 1;
% pause(0.1);
% if e==5 && max(tempF)>=120
% time=0
% end
end
ee=num2str(e)
t=[1:200];
tempF2=fliplr(tempF);
plot(t,tempF2);
title('Time vs. Temperature')
ylabel('Temperature(F)')
xlabel('Time(s)')
saveas(gcf,'tempplot.jpg')
mail= 'sara.enani@gmail.com'
password='Srsora123#'
host='smtp.gmail.com'
setpref('Internet','SMTP_Server',host);
setpref('Internet','E_mail',mail);
setpref('Internet','SMTP_Username',mail);
setpref('Internet','SMTP_Password',password);
props = java.lang.System.getProperties;
props.setProperty('mail.smtp.auth','true');
props.setProperty('mail.smtp.socketFactory.class', 'javax.net.ssl.SSLSocketFactory');
props.setProperty('mail.smtp.socketFactory.port','465');
sendmail(mail,'Hello Train Station! There are this many passengers in the train',ee,'tempplot.jpg')
