Introduction: Desert Themed Mini Cafe!!
Hello, my name is Meera I'm an 18-year-old student learning blender. Today I made this mini desert-inspired cafe! I hope you enjoy:) I uploaded both video and picture tutorial to teach you how to make your own cafe
You will only be needing blender to make this cafe, basic blender skills will be helpful! If you dont know the blender program and its your first time dont be intimidated by the software, its really easy to learn once you know the basics. I self learned blender and I believe you can do it as well!
Step 1: MAKING THE BUILDING
- Add a cube.
- Add 30 loop cuts to the cube.
- Select random faces from the sides of the cube.
- Extrude the selected faces along the Y-axis.
- Repeat the same steps for the roof of the cube.
- Add a mirror modifier to create a unique pattern.
Step 2: Shaping the Door
- Add a cube with the preferred dimensions of your door.
- Apply a bevel modifier with 15 segments.
- Inset a new face on the cube, then delete that face. Afterward, bevel the edge loops.
- Ensure that your door touches the café wall.
- Delete the button face from the door.
Step 3: Designing the Door
- Select every other inner face and scale it inward.
- Add two cubes to the side of the door.
- Click on the selected parts and scale them inward.
- Fit the door into the front wall.
- Delete the face of the front wall and click "Fill" to create a single face.
- Select the new face and use the knife tool to outline the door.
- Add the mirror modifier with the specified settings and delete unnecessary faces.
- Add a floor.
- Done!
Step 4: EXTERIOR MATERIAL PAINTING
- Select the cube and perform UV unwrapping.
- Then, select the inner faces and apply your desired material and color.
- Next, select the outer faces and apply a different material and color.
Step 5: INTERIOR DECOR
For the interior decor there are no specific requirements, just have fun!
- I created a counter with this style by adding a cube creating many loop cuts and extruding every other face
- then I added a countertop and beveled the edges to get smooth corners
- I created 2 styles of cupboards one for the bottom row and one for the top.
- I added the cupboards to the inside of the cafe and on the bottom row of cupboards I added a countertop with a sink
- I then added interior decor for the cafe, food lights, cash register. cups. I used some free resources to get decor.
- I then used Canva to create a sign then added it to a frame and the front of the cafe
- At last, I started adding different materials based on my preferred look, for example,e for the cupboards, I added glass doors, and for counters I used wood.
Step 6: Video Tutorial
Heres a full in-depth video on how to make the cafe!
You can color and make ithe nterior as you wish but this is the way I did it.
Step 7: Result
In the end, you’ll be getting a stunning desert-themed café! Please let me know if you enjoyed my tutorial. I worked hard to create this café. The render didn’t come out perfectly, as my laptop is quite old and struggles to handle Blender’s capabilities. Nevertheless, I hope you found the tutorial enjoyable! :)
