Design Robot Legs
Intro: Design Robot Legs
If your robot have bored of wheel movement, this instructables show you how to design and make Theo Jansen's Strandbeest legs (without 3D printer) for you robot.
Ref.:
STEP 1: Geometry Design
GeoGebra can help you design the mechanics of the robot legs:
http://www.geogebra.org/download
Try download and install GeoGebra and then open the attached file Beest.ggb, press play button at the left bottom corner. You can see how it works!
Every value at the left hand side slider can be adjust and it can real time show the effect at the diagram.
Once the legs movement seems fine for you, remember your adjusted value, it will use in next steps.
STEP 2: Prepare Material
The most difficult things of making strandbeest legs is it require at least 3 pairs of legs in each side to make it move.
So after you have designed how to assemble one leg, you need to duplicate 11 more at the same size.
The materials show at the pictures all are in 2 mm thick or with 2 mm hole. (Except those paper clip :P)
Some of 2 mm axle I am using carbon fiber, it is about weight concern.
ref. - my purchasing list (some items buy in bulk):
1 x https://world.taobao.com/item/42387486078.htm
24 x https://world.taobao.com/item/43642147383.htm
1 x https://detail.tmall.com/item.htm?id=16258413656
2 x https://detail.tmall.com/item.htm?id=36513239827
1 x (2*200mm) https://detail.tmall.com/item.htm?id=27151568421
2 x (2*300mm) https://detail.tmall.com/item.htm?id=27151568421
1 x https://detail.tmall.com/item.htm?id=37107254173
1 x (20-2A) https://detail.tmall.com/item.htm?id=20252165378
1 x (3*2.1*250) https://detail.tmall.com/item.htm?id=18504725074
2 x https://detail.tmall.com/item.htm?id=16254906563
4 x (2*200mm) https://detail.tmall.com/item.htm?id=20645288443
1 x https://detail.tmall.com/item.htm?id=16272162447
6 x https://detail.tmall.com/item.htm?id=16270990575
8 x (2mm) https://detail.tmall.com/item.htm?id=20623304447&...
2 x https://world.taobao.com/item/40354674288.htm
2 x (3mm) https://world.taobao.com/item/37550271279.htm
3 x https://detail.tmall.com/item.htm?id=36190401824
1 x https://detail.tmall.com/item.htm?id=37601413324
STEP 3: Assemble
STEP 4: Controller
The legs are drive by a motor on each side, you can drive it by RF sender + receiver, Arduino + BT, ESP8266, etc...
If you are using Raspberry Pi, Magpi issue 9 cambot is a good example of how to remote control a two motor robot. I am using it in the demo video.
ref.:
STEP 5: Put It on the Playground!
STEP 6: Video
Sorry that my Raspberry Pi board and camera have removed to another project and the legs have some defect after playing with some children.
This is the my second trial of making robot using Raspberry Pi and Strandbeest legs, I called it CreaturePi Mark II. I am working on CreaturePi Mark III now, may show you later in Instructables.
The last bonus video was capture form the remote iPad and CreaturePi Mark I.
5 Comments
Wrrr 10-G 8 years ago
Excellent work, congratulations.
eido w 8 years ago
hello 陳亮,
very beautiful and creative design. I was wondering from where did you buy the 90 degree flat bracket, I did not see it on the purchase list. Any chance for a link?
thank you very very much!!
陳亮 8 years ago
陳亮 8 years ago
JulianAzz 8 years ago
