Introduction: Design and Construction of a 40W LED Driver Board With PWM Control
About: Hello, I'm Saverio, an Electronics & Telecom Engineer who loves crafting innovative solutions. From coding to PCB design and 3D modeling, I bridge the gap between ideas and reality. Let's explore the world of …
If you've ever dreamt of controlling light with the precision of an artist wielding a brush, you're in the right place. In this tutorial, we'll guide you through the creation of a custom LED driver, perfect for your next lighting project. Our secret weapon? The reliable and powerful AL8861.
☕ Support the Project
All my projects are shared for free, with the goal of helping and inspiring others in the maker and open-source community.
If you’d like to support my work and help me keep creating new projects, you can make a small donation:
👉 Donate via PayPal: https://www.paypal.com/donate/?hosted_button_id=V6D9QA874HT58
Your support — no matter how small — makes a big difference.
Thank you for keeping these projects alive and accessible to everyone! 🙌
Before commencing the assembly of our PWM LED driver, it's essential to gather all necessary supplies:
  1. AL8861 LED Driver: A high-quality component crucial for PWM-controlled LED operation, capable of handling up to 40W of power.
  2. Microcontroller: For controlling the LED driver via PWM signals.
  3. Custom PCB from JLCPCB: Tailored to our project's specifications, facilitating the integration and connectivity of components.
  4. Other Electronic Components: Various components such as resistors, capacitors, connectors, and wiring essential for circuit assembly and functionality testing.
Step 1: Project Overview
The genesis of our project arose from the necessity to implement Pulse Width Modulation (PWM) control for an LED lamp using an ESP32 microcontroller. Despite extensive market research for an appropriate LED driver, no existing solution proved adequate. Consequently, we embarked on developing a bespoke LED control board.
Step 2: AL8861: Core Component
Central to our project's functionality is the AL8861, a premium-grade LED driver renowned for its efficiency and PWM compatibility. Selected for its ability to deliver up to 40W of power, the AL8861 ensures precise brightness control and extends the operational lifespan of the LED lamp significantly.
The AL8861's technical specifications underscore its superiority:
  • PWM Control: Offers precise adjustment of brightness levels, ideal for dynamic lighting effects.
  • High Efficiency: Boasts over 90% efficiency, minimizing energy consumption and optimizing power utilization.
  • Wide Input Voltage Range: Versatile, accommodating input voltages from 4V to 40V, suitable for diverse power supply configurations.
  • Output Current Regulation: Maintains stable current output, ensuring consistent illumination under varying conditions, capable of delivering up to 1.5A.
  • Over-Temperature Protection: Safeguards against overheating with active temperature monitoring, operational adjustments, and a threshold typically set at 150°C.
  • Wide Temperature Range: Functions reliably in temperatures ranging from -40°C to 85°C, suitable for both indoor and outdoor applications.
  • Long Lifespan: Robust design enhances LED longevity, reducing maintenance and replacement costs significantly.
These attributes position the AL8861 as pivotal to our project, offering unparalleled control, efficiency, reliability, and adaptability essential for high-performance LED lighting applications.
Step 3: Collaboration With JLCPCB
Collaboration with JLCPCB was instrumental in realizing our vision. Their expertise in custom PCB production facilitated the creation of a tailored control board housing the AL8861. The outcome was a professionally crafted, high-quality product meeting our exacting standards.
Step 4: Build Process Overview
Now, let's delve into the detailed steps of our PWM LED driver assembly:
  • Material Procurement:
  • AL8861 LED Driver
  • Microcontroller for PWM Control
  • Custom PCB fabricated by JLCPCB
  • Other essential electronic components
  • Circuit Design:
  • Utilizing electronic design software, we formulated a comprehensive schematic integrating the AL8861 and ESP32.
  • Pin configuration included VCC (up to 40V), GND, PWM, LED+ and LED-.
  • PCB Production:
  • Leveraging JLCPCB's services, we initiated custom PCB production tailored to our project specifications.
  • Component Assembly:
  • Methodically assembled components onto the PCB, adhering strictly to AL8861's operational requirements.
  • Testing and Refinement:
  • Rigorously tested the functionality of the LED driver, iterating as necessary to optimize performance.
Step 5: Conclusion
The integration of the AL8861 and collaboration with JLCPCB culminated in the successful creation of a custom PWM LED driver exceeding our expectations. Empowered with precise lighting control capabilities, our innovation promises to illuminate environments with artistic mastery and technical finesse.
We eagerly anticipate witnessing your creative applications of the custom LED driver. Share your ideas and questions below and showcase your projects on Instructables to inspire fellow enthusiasts.
Step 6: Ready-Made Solutions
For those preferring a streamlined solution or wishing to directly support our project, pre-assembled versions of the PWM LED driver board are available for purchase:
  • Tindie Store: Visit our official Tindie store for meticulously crafted, tested, and ready-to-use PWM LED driver boards. Tindie Store Link
  • Etsy Shop: Explore our Etsy shop for hand-assembled PWM LED driver boards, ensuring the same high-quality performance as the DIY version. Etsy Shop Link
Your patronage not only secures a top-tier LED driver but also directly supports future innovations. Feel free to reach out with inquiries or customization requests; we're committed to assisting you in achieving optimal lighting control solutions.
