Introduction: Designing a 1.2 KW DC-DC Converter
About: With nearly a decade of industry experience, our company boasts a professional team dedicated to ensuring product quality control and electronic component procurement. Our robust supply channels make Ovaga an …
The objective of this project is to design and implement a DC-DC converter circuit that can step down a high input voltage (e.g., 400 V) to a lower output voltage (e.g., 48 V) using the FP35R12U1T4 IGBT. This converter will be capable of delivering up to 1.2 kW of power.
The FP35R12U1T4 is an Insulated Gate Bipolar Transistor (IGBT) suitable for high-power applications, particularly in the field of power electronics. This project focuses on designing a 1.2 kW DC-DC converter using the FP35R12U1T4 IGBT, which will be used for renewable energy systems, electric vehicles, or industrial applications where efficient voltage regulation is crucial.
Key Features of FP35R12U1T4
  1. Voltage Rating: 1200 V
  2. Current Rating: 35 A
  3. Low Saturation Voltage: Ensures high efficiency.
  4. Fast Switching Speed: Suitable for high-frequency applications.
  5. Thermal Resistance: Low thermal resistance for improved heat dissipation.
  1. FP35R12U1T4: IGBT transistor.
  2. Diode: Suitable fast recovery diode rated for at least 1200 V and 35 A.
  3. Inductor: Properly rated inductor for smoothing output.
  4. Capacitors: Input and output capacitors to filter voltage ripples.
  5. Controller IC: PWM controller IC (e.g., TL494) for driving the IGBT.
  6. Resistors: Gate resistors for controlling the IGBT switching.
  7. PCB: For circuit assembly.
Step 1: Circuit Connections
  1. Input Voltage (Vin): Connect the high voltage source (e.g., 400 V) to the input side of the circuit.
  2. Inductor (L): Place an inductor between the IGBT collector and the output capacitor to smooth the output voltage.
  3. Diode: Connect a fast recovery diode in parallel with the IGBT to handle reverse current when the IGBT turns off.
  4. PWM Controller: Use a PWM controller to drive the gate of the IGBT. The duty cycle will determine the output voltage.
  5. Capacitors: Use appropriate input and output capacitors to filter voltage fluctuations.
Schematic Diagram
The schematic diagram for the DC-DC converter is as follows:
| PWM Controller |
+-------| Vcc Vout ----> +48 V
| Inductor
| Diode
| FP35R12U1T4
+-------------- GND
Step 2: Component Selection
  1. Diode: Choose a fast recovery diode rated for at least 1200 V and 35 A, such as the MB6S-1200.
  2. Inductor: Select an inductor rated for the desired output current (e.g., 10 mH) and sufficient current handling.
  3. Input Capacitor: Use capacitors rated for at least 450 V and with a capacitance of 100 µF or higher.
  4. Output Capacitor: A low ESR capacitor rated for at least 63 V and a capacitance of 470 µF.
Step 3: PCB Layout Considerations
When designing the PCB for this project, the following considerations are crucial:
  1. Thermal Management: Ensure sufficient copper area around the IGBT for heat dissipation. Consider adding a heatsink.
  2. Ground Plane: Use a solid ground plane to minimize EMI and ground loop issues.
  3. Trace Width: Calculate the width of traces based on current capacity to prevent overheating.
  4. Component Placement: Place components with high switching currents close to each other to minimize inductance.
Step 4: Performance Testing
Testing Setup
  1. Power Supply: Connect an adjustable power supply (e.g., 400 V) to the input.
  2. Load: Connect a resistive load rated for 1.2 kW to the output.
  3. Oscilloscope: Use an oscilloscope to monitor the output voltage and waveform.
Expected Results
  1. Output Voltage: The output voltage should be stable at approximately 48 V under load conditions.
  2. Efficiency: Measure the efficiency using the formula:
  3. Efficiency(%)=(PoutPin)×100Efficiency(%)=(PinPout​​)×100
  4. where PoutPout​ is the output power (approximately 1.2 kW) and PinPin​ is the input power.
Troubleshooting
If the circuit does not perform as expected:
  1. Check Connections: Verify all connections and solder joints.
  2. Measure Voltages: Use a multimeter to check voltages at different points.
  3. Inspect Components: Ensure all components are rated correctly and functioning.
Conclusion
This project demonstrates how to design a high-power DC-DC converter using the FP35R12U1T4 IGBT. By following the outlined steps, you can create an efficient and reliable power supply suitable for various high-power applications, such as renewable energy systems and electric vehicles.
