Introduction: Desk It to the Limit: Print Your Perfect Organizer!
Let’s face it: no matter how organized we think we are, our desks eventually turn into chaotic catch-alls for pens, cables, paperclips, sticky notes, and whatever else ends up there. I found myself constantly searching for things in the clutter and that’s what inspired this project.
Rather than buy a mass produced desk organizer that may not fit my needs (or aesthetic), I decided to make one myself. And what better way to do that than with a Bambu Lab X1 Carbon, a powerful CoreXY 3D printer known for its blazing speed and intelligent features like AI-based first-layer inspection.
This project wasn’t just about printing an object, it was about learning to bring a digital design into the real world. Whether you're new to 3D printing or a seasoned maker looking for a weekend build, this step-by-step guide will walk you through the process of choosing or creating a design, slicing it properly, and getting a clean, polished print using the X1 Carbon.
Let’s dive in and create a desk organizer that’s actually organized because you deserve a workspace that works for YOU!
Tools and Equipment:
  1. Bambu Lab X1 Carbon 3D printer (or another Bambu printer model)
  2. A computer with Bambu Studio slicer installed
  3. Filament: PLA, PETG, or ABS (depending on your needs: I used PLA for my project)
  4. Optional: Pilers or another scraping tool to remove supports
  5. Optional: Tinkercad for customizing your organizer
  6. Optional: Super glue to attach any separate components
Files:
  1. STL file of a desk organizer: included in this post (you can also find another downloadable file or create your own self-designed organizer)
Step 1: Find or Design Your Desk Organizer
You’ve got two solid options:
Option A: Download a Ready-Made Design
Download my STL file (which is linked below) or find another design online that you like. There are countless free desk organizer models online. Try:
  1. Printables.com
  2. Thingiverse.com
  3. MakerWorld.com
Look for modular systems if you want to expand later. I recommend customizing these files using Tinkercad to make them unique and best fit your organizational needs!
Option B: Design Your Own
Use beginner-friendly software like Tinkercad, or more advanced tools like Fusion 360. This allows you to:
  1. Size compartments based on what you actually use
  2. Add personalized text, labels, and engravings
  3. Match it to your desk’s layout
Step 2: Prepare the File in Bambu Studio
  1. Open Bambu Studio and import your STL file.
  2. Adjust orientation, scale, or duplicate parts if needed.
  3. Choose a material preset (PLA is a great default).
  4. Select a print profile:
  5. Standard for most prints
  6. High-Speed for faster turnaround
  7. Set infill (15% is ideal) and layer height (0.2mm is a good balance).
  8. Preview the print, check for overhangs, and enable supports if necessary for your design.
Once you’re satisfied, click “Slice” and review the estimated time and filament usage.
Step 3: Prepare Your 3D Printer
  1. Power on your printer.
  2. Clean the print bed to ensure good adhesion.
  3. Load your chosen filament directly into the extruder.
  4. Check the nozzle and bed for debris or filament residue.
  5. Use Bambu Studio to connect to your printer over Wi-Fi or via SD card.
Tip: The Bambu X1 Carbon will auto-calibrate and level the bed at the beginning of each print, so you don’t have to worry about manual adjustments.
Step 4: Print Your Organizer
  1. Send the sliced file to the printer via Wi-Fi or SD card (personally, I used an SD card).
  2. Confirm the print on the touchscreen.
  3. Watch the first few layers to make sure the adhesion looks solid.
  4. Let it run! Check on the printer periodically to ensure that everything is working properly.
Depending on the complexity, your desk organizer may take a couple of hours to print—or overnight for larger multi-part systems. My organizer took around 4 hours to fully print!
Step 5: Remove the Organizer and Add Final Touches
  1. Wait until the bed cools down, then gently remove the print.
  2. Remove any brims, supports, or stringing with care.
  3. Use pliers of another scraping tool to fully remove any supports left on your organizer.
  4. If you printed additional components separately, use super glue to attach them to the main structure.
  5. Optionally, paint or label compartments to keep things organized.
This project taught me more than just how to print a cool object—it gave me insight into the workflow of turning an idea into a physical product.
Here are a few key takeaways:
  1. Planning matters: Whether it was designing a custom compartment or choosing the right print settings, taking the time to plan ahead saved hours of rework.
  2. Understanding your tools: The Bambu Lab X1 Carbon is a beast of a printer, but learning to fully use its features helped me work more efficiently.
  3. Making for yourself is powerful: Creating a solution tailored to my actual needs feels so much more satisfying than buying something generic.
Step 6: Put Your Organizer to Work!
Now that your desk organizer is fully printed, assembled, and cleaned up, it’s time for the most rewarding part: putting it to use!
Here are a few ways you can make the most of your new setup:
Load It Up:
Start filling each compartment based on how you actually use your space. You might organize by:
  1. Writing tools: pens, pencils, markers, highlighters
  2. Office essentials: paperclips, sticky notes, scissors, thumb drives
  3. Tech accessories: SD cards, USB hubs, charging cables, earbuds
  4. Hobby tools: precision screwdrivers, craft blades, glue sticks, etc.
Customize for Productivity:
  1. Add labels to compartments with a label maker
  2. Use different colors for different categories if you printed modular units
  3. Keep the most-used items within easy reach for better workflow
Show Off the Finishing Touches:
If you added decorative elements—similar to the flowers I printed separately and glued on—it's now time to admire how they personalize your organizer and make it truly one-of-a-kind.
Share It!
Take a photo of your finished, fully stocked organizer and share it with the 3D printing community online. Whether it’s on Reddit, Printables, MakerWorld, or Instagram, your solution might inspire someone else to tackle their desk chaos—or remix your design!
Reflecting on the Process:
In the end, this wasn’t just a way to clean up my desk, it was a hands-on learning experience in design thinking, digital fabrication, and personal problem solving. That’s what 3D printing is all about. Printing this desk organizer pushed me to problem solve in real time, adapt to unexpected issues, and build technical skills that I’ll carry into future projects.
More Than Just an Organizer:
In the end, I walked away not just with a functional desk organizer, but with a deeper understanding of how to bridge the gap between digital design and physical object. There’s something powerful about solving a personal problem with your own hands and tools, especially when the process makes you smarter and more capable along the way. Now, every time I reach for a pen or a sticky note, I’m reminded not just of the object I printed, but of everything I learned in making it. This desk organizer project turned out to be much more than just a way to declutter my workspace, it became a learning experience that tested my creativity, patience, and adaptability. Like most 3D printing projects, things didn’t go exactly as planned, but those unexpected moments taught me the most.
When the Filament Runs Out…
One of the biggest surprises came mid-print: I ran out of purple filament, which I had planned to use for the entire organizer. Rather than scrap the print or start over, I decided to switch to green filament for the remaining sections. At first, I wasn’t sure how the two-tone look would turn out, but in the end, it actually added some unexpected character to the piece. It taught me that 3D printing isn’t just about precision, it’s also about embracing the improvisational nature of the medium and making the best of what you have on hand.
Printing Decorations Separately:
I had also included flower shaped decorations as part of the original model. Unfortunately, they didn’t print cleanly when combined with the main body; the fine details either didn’t adhere properly or came out stringy. Rather than reprint the entire organizer, I decided to separate the flowers into their own print job. By printing the flowers separately in a different color, I had better control over the quality. Once they were finished, I carefully super glued them onto the organizer, which gave me a cleaner finish and more flexibility in their placement. That workaround not only salvaged the design but also helped me understand how breaking complex prints into smaller, manageable parts can often lead to better results.
Skills I Developed Along the Way:
These challenges forced me to adapt—and through that, I gained some valuable skills:
  1. Filament management: I learned to keep an eye on filament levels and how to handle mid-print material changes without compromising the final look.
  2. Model separation and part planning: Breaking decorative elements into separate prints gave me a clearer sense of how to organize multi-part projects, especially when fine detail is involved.
  3. Problem-solving mindset: I didn’t panic when things went wrong. Instead, I stepped back, found alternatives, and kept the project moving forward. That’s something I’ll take with me on all future builds.
  4. Finishing techniques: Using super glue and manual assembly reminded me that post processing is part of the craft, and that mixing digital precision with hands-on finishing can actually improve the final product.
The Final Takeaway:
In the end, this organizer isn’t just functional, it tells a story. The purple-and-green color combo, the hand-applied flowers, and the small imperfections are all reminders that this object came from problem solving, persistence, and a willingness to adapt. I didn’t just learn how to 3D print a container, I learned how to navigate setbacks, make creative decisions on the fly, and still produce something I’m proud of. And now, every time I sit down at my newly organized desk, I see more than just a printed object, I see the growth behind it.
