Introduction: Desk Solder and Wire Rack
To be able to remove clutter from my desk, and be able to more easily work on electronics projects, I needed a way to be able to hold my solder spool above the work piece that I soldered.
The holder I came up with is this PPR pipe rack that is extremely easy to be built and it is very cheap as well.
Step 1: Materials for the Solder Rack
Above my desk I already have a shelf to accommodate my external monitor so I wanted to make something that will be mounted under it. For the materials, I used a piece of a PPR water pipe with two PPR holding clips for mounting pipes to the wall.
Step 2: Assembly of the Solder Rack
I’ve attached the clips about 10 cm from the ends and applied a piece of double sided foam adhesive to each of the clips. Since the rack will not hold a lot of weight, the tape will be sufficient to hold it in place. If you need to add more weight to it, then you can use screws to attach it.
The attaching process is very simple where I just stick it to the front of the shelf.
Step 3: How to Use It
To add the solder spool, you can easily detach the pipe from the clips, slide the solder or wire spool and then attach the pipe back to the clips. Both ends of the pipe are exposed so you can additional add something there temporarily while you are working.
If you liked this project then be sure to follow me and to subscribe to my YouTube channel!
