Introduction: Desk Tidy
This Desk tidy is made of two separate 3D printed components and polypropylene. For this project you will need access to a 3D printer, polypropylene, a Stanley knife, chisel and sand paper to refine the 3D printed components.
Step 1: Download and Print STL Files
When printing make sure to select the option to print using supports.
Step 2: Refine 3D Printed Parts and Remove Supports
Use a chiesel to remove the supports. Then use sand paper to smooth any rough edges or corners.
Step 3: Cut the Polypropylene
Cut 9 lengths of Polypropylene using a Stanley knife, cutting mat and steel ruler.
- 3× 265mm×35mm For horizontal lengths
- 6×105mm×30mm For vertical lengths
Step 4: Slot Vertical Lengths of Polypropylene Into the Base
Make sure all lengths are equally spaced and straight.
Step 5: Place Top on the Vertical Lengths of Polypropylene
Make sure to insert one piece at a time.
Step 6: Weave Horizontal Strips In-between Vertical Strips
Leave beginning and end of the strips on the inside of the desk tidy for a cleaner finish.
