Introduction: Nightlight Desk Lamp
How i made a desk lamp
Products are as follows:
1 Smart Water bottle, the 33 oz. size
A 2.5 inch branch that.. would fit into the bottle
Epoxy was Dr. Crafty 1:1
Fairy lights were purchased, which required a USB connector
USB power supply
Step 1: Trim
STEP 1
Cut the top off the water bottle. (example not the real Smart Water bottle):
Step 2: Trim
Trim the bark off the branch to fit into the bottle.
After removing the bark and getting the wood to fit.. you can go ahead and stain it any color you like. I used MinWax Ebony
Step 3: Cut the Branch
Cut the branch in a diagonal.
I originally wanted another shape, but this looked better.
After cutting, you can then apply the stain.
Step 4: Start Assembly
After the stain is dry, you can start the assembly.
Put a spot of hot glue on the branch end, and slide the branch half into the bottle.. remember this will be the top of the lamp when complete. Now fill with epoxy. Only fill the bottle enough to cover the wood.
I created a template to hold down the wood so it
didn't float in the epoxy.
Step 5: Drill a Hole
Drill a hole in the bottom of the other half of wood, and insert the fairy lights.
Coil the lights so they fit nicely into the bottle.
Step 6: Fill
Fill the rest of the bottle up to the top with epoxy.
Tape the wood to the outside so it doesn't float in the bottle.
Make sure it is not leaking around the USB cutout.
Now this is where I had a problem... I added too much epoxy at this step.
Step 7: Remove Bottle
After waiting for the epoxy to set, I then removed the bottle.
The bottom needed to be cleaned up a little... so I trimmed off about an 8th in to make it flat and smooth.
I also finished it by adding a piece of felt to the base, to make it slide on the desk surface.
Step 8: Finished
Plastic Contest
5 Comments
2 years ago
Nice job on the lamp :)
Reply 2 years ago
thanks for taking a look at it.
one quick question i am not sure if my computer is acting up or what but the Plastic contest says there are 37 entries but i can only see 36.
what's up with that.
Reply 2 years ago
Usually it is just a page cache issue. If you refresh the page, clear your browser's cache, or just give it some more time, the numbers should sync up :)
2 years ago on Introduction
Very cool lamp!! It looks so unique and calming.
2 years ago on Step 8
Amazing lamp, truly unique!
