Introduction: Desktop Water Fountain for Peaceful Sound of Flowing Water
I have always loved those mini fountains that come as decorative pieces. The sound of flowing water gives you a peace of mind. Dim lighting, a good book, a cup of espresso and distant sound of flowing water is all i need at any point of time to relax.
The problem with the fountains is they are damn costly. So as my wife and nosy kid has gone for a vacation, I thought this will be a good time to make my own fountain.
Step 1: Materials
Pot to hold everything
Smaller pots for support
Chinese submersible pump
Earthen pitcher (can be changed as like)
Rubber pipe used as extender
Wire mesh for saving the pump inlet from the gravel
Gravel/stones for decoration
Water resistant putty for binding
Step 2:
To start with seal all the out lets of the flower pot with the putty.
When everything dries (mine took around 1 hour), put the water and the pump and test for the water flow and height.
Step 3: Safety Net
Now secure the pump where required. I used a pea size putty piece and pressed the pump down. Also put the smaller pots for support.
Take a wire mesh and cut to size. Make hole for the outlet and secure it in place with the putty. Another hour to dry.
Step 4: The Outlet
As the putty is drying, take the pitcher and mark it as to where the hole will be where the pump outlet will go in. Slowly make a hole to the size. I did it with an old kitchen knife. You may want to soak the terracotta pot in water before drilling or it may chip of large chunks or break it too.
Step 5: Decorating
As the mesh is secured, put in the stones to fill it up. Make sure not to put anything in the pump outlet. I just closed it with my thumb and spread the gravel around. Now put a ring of putty on the pump outlet and adjust the pitcher so that it is adjusted properly. You may need some adjustment to set it right. Also need some thing to hold it till the putty dries.
Step 6: Finally
Fill it with water and put the power on. Hopefully everything works fine as you plug it in. You can use it as it is now. Or you can put some decorative pot or plants under the pitcher. Right now in my setup the bottom pot is tilted slightly toward the pitcher so the water cascades in 2 steps.
Automation Contest
5 Discussions
5 years ago on Introduction
Add a couple of spring peepers (those are those tiny frogs) for the chirping sounds and you are all set.
Are you using tap water? Just wondering because as the water evaporaates it leaves behind deposites so if your water is hard it might require distilled water.
Reply 5 years ago on Introduction
With spring peepers do you mean the real ones? This fountain will be indoor! My wife will kill me if i add them.
And good point about the water. I will change the water today evening when I reach home.
Yeah, real ones would be fun.
When I was a kid we lived in Hawaii for a few years. I got the idea to catch some of the sand crabs I used to see running on the beach and keep them for a little while in a turtle bowel dish, one of those plastic ones that they used to make for pet turtles. I didn't know they could climb up those walls. I heard screams from my sisters as a swarm of crabs went skittering across the floor. Yeah, I got in trouble. But it was worth it to hear the screams.
I am not using real frogs! :P
Great Tute
