Introduction: Detailed Tutorial on How to Make a Blue Seed Bead Stitch Wide Bracelet With Yellow Pearl Beads
This Pandahall article details a tutorial on how to make a handmade blue seed bead stitch wide bracelet with yellow pearl beads. Hope you like the blue seed bead stitch wide bracelet.
Step 1: Supplies Needed in DIY the Blue Seed Bead Stitch Wide Bracelet:
6mm Yellow Round Pearl Beads
2mm White Seed Beads
2mm Blue Seed Beads
10mm White Round Pearl Beads
0.2mm White Fishing Wire
Needle
Stainless-Steel Scissor
Step 2: Make the First Part of the Blue Seed Bead Stitch Wide Bracelet
1st, cut a part of 0.2mm white fishing wire and thread it through a needle. Then, add about 21 2mm white seed beads, a 6mm yellow round pearl bead and a 2mm blue seed bead (as shown in the picture);
2nd, cross the right wire through the yellow round pearl bead and the adjacent white seed bead in sequence (as shown in the picture);
3rd, cross the same wire through the yellow pearl bead and the top blue seed bead again (as shown in the picture);
4th, add 4 blue seed beads (as shown in the picture);
5th, cross the wire through the 4th white seed bead and the blue seed bead and tighten (as shown in the picture).
Step 3: Make the Second Part of the Blue Seed Bead Stitch Wide Bracelet
1st, add a blue seed bead and cross the wire through the 5th white seed bead and tighten (as shown in the picture);
2nd, refer to the above step to add 3 blue seed beads (as shown in the picture);
3rd, add 4 blue seed beads and a yellow pearl bead(as shown in the picture);
4th, cross the wire through the white seed bead and the 11th white seed bead and the yellow pearl bead (as shown in the picture);
5th, cross the wire through the blue seed bead (as shown in the picture).
Step 4: Make the Third Part of the Blue Seed Bead Stitch Wide Bracelet
1st, add 4 blue seed beads;
2nd, cross the wire through the 14th white seed bead and blue seed bead (as shown in the picture);
3rd, refer to the1st step and the 2nd step in Step 2 to add 4 blue seed beads and cross the wire through the white seed beads. Then, add 4 blue seed beads and a yellow pearl bead (as shown in the picture);
4th, cross the wire through the white seed bead, the yellow pearl bead and the blue seed bead in sequence (as shown in the picture).
Step 5: Make the Fourth Part of the Blue Seed Bead Stitch Wide Bracelet
1st, add a white seed bead and cross the wire through the blue seed bead (as shown in the picture);
2nd, tighten the wire;
3rd, add a white seed bead and cross the wire through the 2nd blue seed bead (as shown in the picture);
4th, add 4 white seed beads;
5th, cross the wire through the 6th blue seed bead and the 6th white seed bead (as shown in the picture);
6th, refer to the above steps to add 2 white seed beads and cross the wire through the blue seed beads(as shown in the picture).
Step 6: Make the Fifth Part of the Blue Seed Bead Stitch Wide Bracelet
1st, ad 4 white seed beads;
2nd, cross the wire through the blue seed bead and the white seed bead(as shown in the picture);
3rd, refer to the above steps to add 2 white seed beads and cross the wire through the blue seed beads. Then, add 4 white seed beads (as shown in the picture);
4th, cross the wire through the blue seed bead and the white seed bead(as shown in the picture);
5th, refer to the above steps to add 2 white seed beads and cross the wire through the blue seed beads. Then, add 4 white seed beads (as shown in the picture);
6th, cross the wire through the blue seed bead and the white seed bead. Then, refer to the above step to add a white seed bead and cross the wire through the blue seed bead and the white seed bead (as shown in the picture).
Step 7: Make the Sixth Part of the Blue Seed Bead Stitch Wide Bracelet
1st, refer to the above steps to add 3 white seed beads and cross the wire through the nether white seed beads and the upper white seed beads(as shown in the picture);
2nd, add 4 white seed beads and a yellow pearl bead (as shown in the picture);
3rd, cross the wire through the 7th white seed bead in the middle row. Then, cross the wire through the yellow pearl bead and the white seed bead(as shown in the picture);
4th, add 4 white seed beads. Then, cross the wire through the white seed bead in the middle row the upper white seed bead (as shown in the picture);
5th, refer to the above steps to add 4 white seed beads and cross the wire through the white seed beads in the middle row and the added white seed beads (as shown in the picture);
6th, refer to the above steps to make another white seed bead and yellow pearl bead pattern (as shown in the picture).
Step 8: Make the Seventh Part of the Blue Seed Bead Stitch Wide Bracelet
1st, add a blue seed bead and cross the wire through the left white seed bead and the blue seed bead. Refer to this step to add another blue seed bead (as shown in the picture);
2nd, refer to the above step to add 4 blue seed beads (as shown in the picture);
3rd, refer to the above steps to add 2 blue seed beads. Then, thread 4 blue seed beads(as shown in the picture);
4th, cross the wire through the white seed bead and the blue seed bead. Then, refer to the above steps to add 2 blue seed beads(as shown in the picture);
5th, refer to the above steps to add blue seed beads and cross the wire through the white seed beads and the added blue seed beads (as shown in the picture).
Step 9: Make the Eighth Part of the Blue Seed Bead Stitch Wide Bracelet
1st, add a yellow pearl bead and a blue seed bead;
2nd, cross the wire through the rightmost blue seed bead in the middle row. Then, cross the wire through the yellow pearl bead and the blue seed bead(as shown in the picture);
3rd, add 4 blue seed beads. Then, cross the wire through the 5th blue seed bead in the middle row the left blue seed bead added just now(as shown in the picture);
4th, refer to the above steps to add blue seed beads and yellow pearl beads (as shown in the picture);
5th, refer to the above steps to make more such patterns (as shown in the picture).
Step 10: Make the Rest Part of the Blue Seed Bead Stitch Wide Bracelet
1st, cross the wire through the external blue seed beads. Then, add about 20 blue seed beads (as shown in the picture);
2nd, make a hoop with the 20 blue seed beads by crossing the wire through the blue seed beads (as shown in the picture);
3rd, refer to the above step to make another blue seed beads hoop (as shown in the picture);
4th, add 3 white seed beads, a white round pearl bead and a white seed bead to the other wire (as shown in the picture);
5th, cross the wire through the white pearl bead. Then, add 3 white seed beads and cross the wire through the external white seed beads (as shown in the picture);
6th, refer to the above step to make another such white pearl bead pattern (as shown in the picture);
Step 11:
connect the two sides of the blue seed bead stitch wide bracelet together (as shown in the picture).
Step 12:
Here is the final look of the blue seed bead stitch wide bracelet with yellow pearl beads.What do you think of this blue seed bead stitch wide bracelet with yellow pearl beads? The bead stitch process is a little complicated, but once you grasp the basic pattern, you may find it's not that difficult as you might think. If you're interested in this blue seed bead stitch wide bracelet, you can collect some seed beads and give it a try.
