Introduction: Detailed Tutorial on How to Make an Exquisite Pearl Bead Flower Pendant Necklace
Searching for pearl necklace designs? Look here! Today we’d like to share you a very exquisite pearl bead flower pendant necklace, I bet you’ll like the design.
Step 1: Materials Needed to Make This Pearl Bead Necklace:
4mm White Pearl Beads
6mm White Pearl Beads
8mm White Pearl Beads
10mm White Pearl Beads
12mm White Pearl Beads
4mm Blue Pearl Beads
6mm Blue Pearl Beads
4mm Blue Bicone Glass Beads
6mm Blue Bicone Glass Beads
3mm Golden Acrylic Beads
2mm Golden Seed Beads
Golden Flower Bead Caps
Silver Jumprings
Silver Headpins
Silver Lobster Clasps
0.2mm Fishing Wire
Round Nose Pliers
Long Nose Pliers
Scissor
Step 2: Make the Beginning Part of the Necklace
1st, cut about 400cm fishing wire, slide a silver lobster claw clasp to the wire, tie a knot and cut off the short extra wire;
2nd, thread 22 6mm white pearl beads, a golden seed bead, a 6mm blue bicone glass bead, and another golden seed bead to the wire;
3rd, alternatively slide three 6mm pearl bead and two golden seed bead to the wire like the third picture shows;
4th, cross the wire through the seed bead next to the bicone glass bead, tighten the wire to make a pearl bead loop;
5th, thread the wire through the surrounding beads like the last picture shows.
Step 3: Make the First Beaded Flower Pattern
1st, add a golden seed bead, a 8mm pearl bead, a golden seed bead, a 6mm pearl bead, a golden seed bead, a 8mm pearl bead, and a golden seed bead to the wire;
2nd, cross the wire back through the previous 6mm pearl bead like the second picture shows;
3rd, add a 4mm blue bicone glass bead, a golden seed bead, and a 4mm blue bicone glass bead to the wire;
4th, cross the wire through the right 6mm pearl bead like the fourth picture shows;
5th, add a 4mm bicone glass bead to the wire and cross the wire through the middle golden seed bead like the fifth picture shows;6th, add another 4mm bicone glass bead to the wire and cross the wire through the surrounding beads like the last picture shows.
Step 4: Make the Base of the Second Pearl Bead Flower Pattern
1st, add 9 beads to the wire in order, the beads are: a golden seed bead, a 4mm bicone glass bead, a golden seed bead, a 4mm pearl bead, a golden seed bead, a 8mm pearl bead, a golden seed bead, and two 4mm pearl beads;
2nd, cross the wire though the first 4mm pearl bead and the nearby golden seed bead and 8mm pearl bead, just like the second picture shows;
3rd, add a 3mm acrylic bead, a 8mm pearl bead, a golden seed bead, three 4mm pearl beads, and a golden seed bead to the wire;
4th, cross the wire back through the 3mm acrylic bead and the 8mm pearl bead like the fourth picture shows;5th, repeat to make two more 8mm pearl bead patterns to form a flower pattern like the last picture shows.
Step 5: Finish the Second Pearl Bead Flower Pattern
1st, alternatively slide 2 golden seed beads and a 4mm blue pearl bead to the wire, and then cross the wire through the nearby 8mm pearl bead;
2nd, repeat to add another three 4mm blue pearl beads to the flower pattern in the same way;
3rd, alternatively add three golden seed beads and two 6mm bicone glass beads to the wire and cross the wire through the opposite 4mm blue pearl bead;
4th, add another 6mm blue bicone glass beads in the same way, tighten the wire to make a blue bead flower.
Step 6: Make the Base of the Third Pearl Bead Flower Pattern
1st, slide a golden seed bead, a 4mm bicone glass bead, a golden seed bead to the wire and cross the wire through the 6mm pearl bead on the first flower pattern to connect the second and the first beaded flowers together;
2nd, cross the wire through the second flower bead pattern;
3rd, add 9 beads to the wire in order, the beads are: a golden seed bead, a 6mm bicone glass bead, a golden seed bead, a 6mm pearl bead, a golden seed bead, a 10mm pearl bead, a golden seed bead, and two 6mm pearl beads;
4th, cross the wire through the first 6mm pearl bead and the 10mm pearl bead to make a flower petal;
5th, add a 3mm acrylic bead, a 10mm pearl bead, a golden seed bead, three 6mm pearl beads, and a golden seed bead to the wire and cross the wire through the 10mm pearl bead to make the second flower petal; and then repeat to make the rest two flower petals in the same way.
Step 7: Complete the Third Flower Pattern and Star to Make the Other Half of the Necklace
1st, repeat the step 4 to finish the glass bead flower of the third flower pattern, but we need to change the 4mm blue pearl beads to 6mm blue pearl beads this time;
2nd, thread the wire to the top of the third pearl flower pattern and add 9 beads to the wire, the beads are: a golden seed bead, a 6mm bicone glass bead, a golden seed bead, a 4mm pearl bead, a golden seed bead, a 8mm pearl bead, a golden seed bead, and two 4mm pearl beads;
3rd, repeat step 3 and step 4 to make a beaded flower pattern in the same way;
4th, add 7 beads to the wire to make a connect part, the beads are: a golden seed bead, a 4mm blue bicone glass bead, a golden seed bead, a 6mm pearl bead, a golden seed bead, a 4mm bicone glass bead, and a golden seed bead;
5th, cross the wire through the nearby flower petal and cross it back through the nearby beads like the last picture shows.
Step 8: Finish the Pearl Bead Flower Pendant Necklace
1st, repeat step 2 and step one to make a small beaded flower pattern and the ending part in the same way;
2nd, attach a silver jumpring to the end of the necklace;
3rd, slide a 4mm bicone glass bead, a flower bead cap, and a 12mm pearl bead to a headpin, make a loop to fix them;4th, add a silver jumpring to the bottom of the middle flower pattern and attach the bead link to the jumpring.
Step 9: Here Is the Finished Pearl Bead Flower Pendant Necklace:
Wow! What a delicate pearl bead necklace! Absolutely, it will take your time to make such a beautiful necklace, but the finished work will show you it definitely deserves your time! Just as you can see, all the patterns are the same, all you need to do is change the size of beads. So, if you like it, don’t hesitate, just take your time and try to make one!
