Introduction: DiY Solar Panel & Measure Datas
Test equipment: one solar panel, 12V12AH battery, 10A solar charger. The aim of the research is to develop a power supply solution that can power our measuring and Lora GW devices in the long run. in stage 2, we continuously measure and record the voltage of the solar cell and the battery for 1 year together with the temperature and humidity data. The results of the tests, I will be made public. Anyone can use it.
The picture shows a solar cell, DIY made 7 years ago. The goal was to find the right impregnator -20 +40 °C
Step 1: The Cell
Step 2: Making the Panel Soldering
Step 3: Making the Panel Soldering
Step 4: The Panel
Step 5: Charge Controller
Step 6: Mistake
When colleague Chen had a really bad day in work ;)
Step 7: First Test
battery voltage
Step 8: The LoRa Gateway Is Working!
Step 9: Charging Process
Step 10: Full Sunshine Partly Cloudy
Step 11: I Added 12v 12Ah Battery
Step 12: Measuring Difference Between 12v 12Ah and 12v 24Ah Battery
Step 13: Cloudy Weather
Step 14: Measurements
Step 15: Fog on Week
Step 16: Family Side Effect, Night Lighting From Solar Charged Battery
The bottles on the desk, tomatoes bottles..
Step 17: Mistakes
1, pushed hard the solder
2, first try impregnator: epoxy resin
