Introduction: Dice Tower
Hi All,
Today I will share how to make a dice tower, Though Dice towers are not as popular in India, I wanted to make it as decoration, So one can use this to play with kids or as a decoration. Most of the things used are avaliable at home and you do not need a 3d printer to build one
Few years back I made "falling dominos", which I made for my son, which he was not using / playing with, any more. So I decided to reuse them as stairs in the dice tower.
This helped in reducing build time too
Hope you like it, Please share your comments, Video Link
Step 1: What Do We Need ?
Material
- Empty Pringle box
- Wooden strips or blocks
- Cardboard ( Corrugated box )
- Tissue paper
- Acrylic Paints
- PVA glue / fevicol
- Paper cutter
- Scissors
Step 2: Stairs
To Make Stairs
- Measure inner diameter for the pringle box (Mine 70 mm)
- Now we need to drill holes at 35 mm from corners
- Refer the diagram, I drilled holes from flat edge at 30mm
- Glue the wooden strips with inserting a skewer
- Add a 70mm wood block, at the end to stop dice to roll on the back side, as shown
- Add support dowels to it
- Add a SemiCircle cover on the top
- Slide everything inside the pringle box
Step 3: Tower
- Cut a door at the bottom of the box
- Cut 10mm strips for corrugated box
- Glue these strips as shown to give a brick work
- Leave sufficient gap of atleast 1 to 2 mm in between
Step 4: Top
- To make a the top, we need two 90mm circles and long strip on 30mm
- Stick the two circles together with one strip on the sides to make a small cylinder
- Cut 15mm squares on another strip as shown 15mm and stick it on the cylinder as shown
Step 5: Base
- For Base, cut a 100mm circle and 20 mm strips of cardboard
- Glue the strip on the side of the circle to make as small cylinder as shown
Step 6: Paper Mache
- Before we paint anything, we want to close holes and fill gaps
- mix PVA glue ( fevicol ) + water in equal ratio in a container
- Apply tissue paper and this mixture on base, top and tower as shown
- Let it dry for few hours
- We do not want to overdo, one or two layers are enough
- Do not apply too much of the liquid mixture, as this could harm the overall shape of each structure
Step 7: Paint Job
- I used acrylic colors
- Brown paint as base
- Dry brush : Green, White and hint of black
- I highlighted all bricks using a black sketch pen
- Even drew brick work on the base and top
Let it dry for few hours and then You are ready to play with it
I hope you like this, Please share comments and suggestions
