Introduction: Dice Using AutoDesk Fusion 360
Hello, I am a student of APS School, West Bengal.
In this project, we will use Fusion 360 to create a Dice. You can even 3d print this Dice using a 3d Printer.
You will require AutoDesk Fusion 360 to design this Dice.
Step 1: Create a Square
The first step in order to create a 3D Cube is to create a Square so it can be used for our dice. If you have basic knowledge of Fusion 360, this should be easy for you.
Step 2: Creating 6 Square to Form a Cube
Now, create six different square connected to each other to form a Cube. Add little circles to the faces. Fold the faces at 90 degrees to form a Cube.
After this you can paint the Cube based on your like and the cube will be ready.
