Digital Bandsaw Blade Tension Gauge
Intro: Digital Bandsaw Blade Tension Gauge
This is a electronic/digital gauge to measure the tension of band saw blades in order to get the best performance from the blade and the saw. Once installed, this device provides a convenient method for measuring the force or tension a bandsaw blade without interfering with the blade guides or attaching something to the blade. This gauge/scale can be setup to display either imperial (default) or metric.
There are several techniques for measuring band saw blade tension. They include commercially available gauges that attach to the blade, and range in price from $200 to $450. A simple and relatively inexpensive technique for Bandsaw Tensioning can be found at Matthias Wandel's website. One of his simplest techniques uses only a digital caliper and a couple of small C-clamps. All of the commercially available methods and including Matthias's are based on the elastic stretching of steel and using Young's modulus to measure the force exerted to stretch the metal bandsaw.
On other technique for tensioning a bandsaw blade is the "Flutter Test". With minimal tension on the blade, the bladesaw tracking is adjusted as would normally be done, and the blade guides are moved up and out of the way of the blade to allow it to flutter freely during this procedure. Next, the bandsaw is started, and the tension is increased until the blade runs straight and true without any "Flutter". American Woodworker has an excellent video on the The Flutter Test which explains this procedure in greater detail.
The methods mentioned above are accurate and reliable, but requires attaching a device to the blade or moving or adjusting the blade guides in order to tension the blade. My device can be setup once after a blade change, and checked each time the blade is used without attaching a device or adjusting the blade guides. It is true that almost all commercially available bandsaws probably have a tension indicator which may or may not be accurate. After testing the scale on my saw I found it to be inaccurate. While searching for solutions, I ran across Carl Holmgren's video Blade Tension 101 that inspired me to build this device. In Carl's video you will see how inaccurate his bandsaw tension gauge was, and the steps he took to calibrate the scale on his gauge.
One source for the proper bandsaw blade tensions can be found at Timber Wolf Bandsaw Blades Blade Tension.
STEP 1: Design Considerations
I constructed my tension gauge in order to have an accurate, and readily available gauge to measure blade tension. A similar device was manufactured by the Carter Products Co. a few years ago, and sold for approximately $200 but is no longer available. This design is specific to the Hitachi Model CB-75F bandsaw, but might be adapted to fit other bandsaw models. One unique feature of the Model CB-75F is its ability to use a 75 mm wide blade. When a 75mm blade is tensioned to 12,000 psi it can exert approximately 1,900 lbs force on the band saw frame and load-cell. If I were using a band saw with a maximum capability of 3/4" wide blades and tensioned to 14,000 psi, the force on the frame would be 546 lbs. Therefore, the load-cell needs to be sized to handle the maximum amount of force (plus spare capacity) applied to them to prevent damaging the sensor. Therefore, I choose a 0-1000 Kg load-cell since this sensor is readily available; had the highest range of force; and is capable of handling the maximum load. Lastly, this load-cell must fit within the same space as the tensioning spring (#95 in Figure #1).
My preference for a micro-controller required the use of Python. This is my preferred language because I used it professionally for many years, and I like it very much. Therefore, I chose to use a Raspberry Pi Zero because it has Python; it's cheap; it has a large support group, and I had several of them. Probably any of the Raspberry Pi Models would work, but I chose the Zero because of space consideration. Processor speed isn't a requirement. Additionally, any of the Micropython boards might work just as well (e.g. ESP8266 or Adafruit Feather HUZZAH, etc.). There's no reason this program couldn't be adapted to an Arduino.
STEP 2: Parts
This device is constructed with off the shelf parts including a Raspberry Pi, Load Cell, HX711 Bridge Amplifier, LCD and other parts costing approximately $100.
PARTS:
1 Raspberry Pi Zero
1 3141_0 - Button Load Cell (0-1000kg) - CZL204
1 HX711 Weighing Pressure Sensor 24 Bit Precision AD Module
1 Microchip Technology MCP23008-E/P 18 pin DIP
1 Yellow Serial IIC/I2C/TWI 2004 204 20X4 Character LCD Module Display
1 Two Channel IIC I2C Logic Level Converter Bi-Directional Module 5V to 3.3V
1 4x4 Matrix Array 16 Key Membrane Switch Keypad
1 GX12-4 GX12 4 Pin Diameter 12mm Male & Female Wire Panel Connector
1 Double Sided Prototype PCB Universal Board
2 Steel disk - 1/4" thick and 50mm Diameter
1 Steel pipe - ID > 27mm and L > 21mm
1 Steel or copper tube - ID > 10mm and L < 7mm
20mm Length of Abrasion-Resistant Polyurethane Rubber, 1-3/4" Diameter- McMaster Carr
20mm Length of Black Delrin Acetal Resin Rod 2-1/2" Diameter- McMaster Carr
1 Bud-Box PN-1324-DG High-Impact ABS NEMA 4x Indoor Box
3 Steel Cups For 1/2" Rare Earth Magnets - Woodcraft
3 Rare Earth Magnet 1/2" x 1/8" - Woodcraft
STEP 3: Electronics
The electronics consist on a Raspberry Pi Zero (RPi) connected to an HX711 module, 4x4 Keypad, 2-Channel Level Shifter, MCP23008 I/O Expansion Chip and a LCD display. The 4x4 Keypad is interfaced to the RPi via I2C and a MCP23008 chip, and I2C is also used to communicate with the LCD display. I2C communications is accomplished through a 2-Channel Level Shifter module which is used just to be on the safe side. The Load Cell is connected to the HX711 module, and the DT and SCK pins of this module are connected directly to pins 29 and 31 of the RPi. Power and Ground for the Prototype PCB and HX711 module are supplied by pins 1, 2, 4 and 6 of the RPi. Pins 2 & 4 are the 5v power pins, which are connected directly to the RPi's power input. Details of the connects can be seen in Figure #3.
STEP 4: Update and Configure the Raspberry Pi
Update the existing software on your Raspberry Pi (RPi) with the following command lines instructions
sudo apt-get update sudo apt-get upgrade
Depending on how out-of-date your RPi is at the time will determine the amount of time needed to complete these commands.
Next, the RPi needs to be configured for I2C communications via Raspi-Config.
sudo raspi-config
The screen seen above will appear. First select Expand Filesystem and select Yes. After returning to the Main Menu of Raspi-Config select Enable Boot to Desktop/Scratch and choose to Boot to Console. From the Main Menu select Advanced Options, and enable I2C and SSH from the available options. Finally, select Finish and reboot the RPi.
STEP 5: Software
Log into the RPi and create the following directories. The /Load_Cell contains the program files and /logs will contain the crontab log files.
cd ~ mkdir Load_Cell mkdir logs cd Load_Cell
Copy the files above to the /Load_Cell folder. I use WinSCP to connect and manage the files on the RPi. Connection to the RPi maybe done via Wifi or serial connection, but SSH needs be enabled in raspi-config to allow this type of connection.
The primary program is BS_tension.py and may be run from the command prompt. In order to test the script enter the following:
sudo python BS_tension.py
As mentioned previously, the BS_tension.py script is the primary file for the scale. It imports the hx711.py file to read the load-cell via HX711 module. The version of hx711.py used for my project comes from tatobari/hx711py. I found this version provided the features I wanted.
The LCD requires the RPi_I2C_driver.py by Denis Pleic and forked by Marty Tremblay, and can be found at MartyTremblay/RPi_I2C_driver.py.
Finally, I modified a version of William Henning'skeypad16.py to communicate with a MCP23008 and 4x4 keypad. I also added a function getkey to the file for use with the BS_tension.py script. The original version of this file can be located by reading the header of the file and following the links.
The config.json file contains the data stored by program, and is modified by several Menu options and at shutdown. The gauge can be setup for either imperial (default) or metric displays. To change the scale to metric change the "imperial_units" parameter to false and save. This should be done when the BS_tension.py script is not running, otherwise the program might overwrite any changes made to the config.json file.
STEP 6: Replacing Spring With Load Cell
Replacing the tension spring with a load-cell is easier said than done. The diameter of the load-cell used was wider than the spring it replaced, therefore, a base was designed and cut-out of a piece of Delrin on my CNC (E in Figure #2). This base fit into the 47mm diameter hole previously used by the spring, and contained a cup to support the 50mm diameter base of the load-cell (D in Figure #2). Since the design used a button load-cell, an adapter was made to focus all the load onto the 10mm diameter by 7mm high button on top of the load-cell. A 50mm diameter by 1/4" thick piece of steel was cut-out and a 6mm high by 10mm ID piece of steel pipe was centered and silver soldered onto the face of the steel disk (C in Figure #2). The same thing was done for the top adapter (A in Figure #2). A piece of 1" steel pipe approximately 22mm long was centered and silver soldered onto the second disk. Finally, a 20mm long piece of 1-3/4" Diameter Polyurethane Rubber (B in Figure #2) was glued between the two adapters using Shoe-Goo.
As can be seen from the photos above, a hole was drilled thru the back of the sliding frame to route the wire for the load cell.
STEP 7: Calibration
Calibrating the gauge is simply a matter of connecting an accurate scale to the slide (108 in Figure #1), and the other end to a part of the lower frame. In my case, I had to remove the belt guard, and tilt the table to rig the scale between the slide and the base. Once this was done, the tension is adjusted with the tensioning wheel and the readings compared. Adjustments are made in the "calibration_factor" variable found in the /Load_Cell/config.json file. In hind site, I should have made a menu option to adjust this variable, but this modification could be easily added to the BS_tension.py file. In any case, I thought that I had calibrated it using a bathroom scale when I had proto-typed it originally, but when I put it on the bandsaw it required more tweaking to calibrate the system. That's my excuse for not adding the calibration menu, and I'm sticking with it.
I do not recommend attaching the scale directly to the wheels. This might deform the wheel since a large load is required to calibrate the gauge. I suggest that you use either the axles or some portion of the upper frame that moves when tensioning the blade.
STEP 8: Main Menu
- Tension - Display the tension on the blade by measuring the Force on the blade divided by the total cross-sectional area of the blade.
- Force - Total force on the blade.
- Settings - This option will take you to another menu to Tare the gauge or input the Dimensions of the blade.
- Shutdown - This shuts down the RPi gracefully to prevent corruption of the data on the SD card.
STEP 9: Tension
Tension - This displays the size of the blade in the upper right-hand corner, and the calculated tension on the blade.
Tension = Force/(Cross-Sectional Area of Blade x 2)
Press # to return to the Main Menu
STEP 10: Force
Force - This display will show the force on the load-cell in either imperial or metric.
Press # to return to the Main Menu.
STEP 11: Settings Menu
Blade Dimension - Press A to enter the Blade Dimension menu.
Tare Scale - Press B to enter the Tare Scale menu.
STEP 12: Dimension of the Blade Menus
Dimensions - Select either Width (1) or Thickness (2) to input data.
Width - Enter the width of the blade from the back of the blade to the gullet, or the thinness width of the blade. Use * on the keypad as the decimal point. Press A to save the information followed by the # to return to the Main Menu.
Thickness - Enter the thickness of the blade. Use * on the keypad as the decimal point. Press A to save the information followed by the # to return to the Main Menu.
STEP 13: Tare Scale
Tare Scale - This should be done each time the blade is changed, and with NO tension on the blade. The gauge will display the amount of Force currently on the load-cell. In my case there happened to be 220.0 lbs force on the cell. Your scale may display something entirely different. With no tension on the blade, press D to tare the scale. This will save the tared weight on the SD card, and will be used next time the scale/gauge is used. Therefore, there is no need to tare the scale again until the blade is changed. After taring the scale, the display should show 0.0 lbs of force. Press # to return to the Main Menu.
STEP 14: Run at Startup
There's excellent Instructable Raspberry Pi: Launch Python script on startup to run a script at startup.
Log into the RPi and change to the /Load_Cell directory.
cd /Load_Cell nano launcher.sh
Include the following text in launcher.sh
#!/bin/sh
# launcher.sh # navigate to home directory, then to this directory, then execute python script, then back homecd / cd home/pi/Load_Cell sudo python BS_tension.py cd /
Exit and save the launcher.sh
We need to make the script an executable.
chmod 755 launcher.sh
Test the script.
sh launcher.sh
Next, we need to edit crontab (the linux task manager) to launch the script at startup. Note: we have already created the /logs directory previously.
sudo crontab -e
This will bring the crontab window. Navigate to the end of the file and enter the following line.
@reboot sh /home/pi/Load_Cell/launcher.sh >/home/pi/logs/cronlog 2>&1
Exit and save the file, and reboot the RPi. The script should start the BS_tension.py script after the RPi reboots. The status of the script can be checked in the log files located in the /logs folder.
3 Comments
GordonBS 4 years ago
Would you be willing to compare the readings from a simple digital bandsaw tension gauge against your super sophisticated Tension Gauge if I sent one to you?
The unit is just a digital caliper with magnets to attach to a blade. Super simple. “SIMONDS DIGITAL TENSION GAUGE”. Item # 50502010, $210
simondsint.com
I just bought one and have no idea how accurate it is.
I just joined “instructables” and am not sure how it works. Are responses also sent to my email or do I need to keep checking this site?
Thank you for your time.
Regards
Gordon
alancurtis2 7 years ago
I thought one of the advantages of a spring in the tensioning system is that it keeps the tension on the blade mostly constant even if there is a high spot on the bandsaw wheels, or tires, or if saw dust gets between the blade and the wheel, or if the wheels are slightly out of true-round.
Do you find that without the spring the indicated force changes with different positions of the wheels?
sbkirby 7 years ago
If you refer to Figure #2 Part B, I glued a 20-22mm thick piece of rubber between the two adapter plates (A and C) as a shock absorber between the sliding plate (#108 in Figure #1), which the upper wheel is attached to, and the load-cell.
This model bandsaw has a brush to remove saw dust from each wheel, therefore, I haven't noticed any significant changes in force while the saw is in operation. Thanks for asking.
