Introduction: Digital Clock
You can Buy All Components directly from me
Contact me on WhatsApp 8989811397
-: Component List :-
1. Atmega328p / Atmega8A 2.16Mhz Crystal 3. 22PF x2 Capecitors 4. 28 Pin Ic Base
5. Led (I Am Using 116 LEDs)
6. Zero PCB 7. Slide On Off switch
8. Push On-Off Switch (1 Pcs)
9. Push Button Switch (2 Pcs) 10. Resistors 100 Ohm (8 Pcs)
Additional Items
1. 3.7 Volt Li-Ion Battery
2. Li Ion Battery Charger
Step 1:
Step 1- Make Single Seven Segment - each line of seven segment is made with 4 LEDs connected in parallel connection, Cathode of all the LEDs are connected together and Anode of 4 LEDs of a group are connected with each other.
Step 2:
Step 2- Make 4 Such Seven Segments, and keep the Cathode of each seven segment saperate and connect then to a male header as shown in the fig below.
Step 3:
Step 3- Connect A segment of all the four Digits together and further connect them with male pin header as shown in the figure.similarly connect B segment of all the 4 Digits together as do it for all the A to G segments.
Step 4:
Step 5:
Step 6:
Manmohan Pal
WhatsApp 8989811397 Email- mannmohanpal@gmail.com Blog: http://electronics4ubymanmohanpal.blogspot.in/p/b... Youtube Channel: http://electronics4ubymanmohanpal.blogspot.in/p/b...
How to make bare bone Arduino on breadboard (ATMEGA328P) by Manmohan Pal
https://www.youtube.com/watch?v=oA_NNvG4dEU
How To Make 8X8 Led Matrix DIY by Manmohan Pal https://www.youtube.com/watch?v=AtG29h2SLpA&t=530s
How to display Scrolling Text on 8*8 LED Dot Matrix by Manmohan Pal https://www.youtube.com/watch?v=cO_O4s2Swus&t=300s
Bluetooth Car using Arduino + HC05 +Android APP by Manmohan Pal https://www.youtube.com/watch?v=1T0QCpnQrOo&t=186s
RF Remote Control Robo Car using 433Mhz RF Module by Manmohan Pal https://www.youtube.com/watch?v=safPeO38_2A
How To Identify 8*8 Led Matrix Pins by Manmohan Pal https://www.youtube.com/watch?v=ZXF62U0ziJ8
RF Remote Control Car Using 433 Mhz RF transmitter and Receiver Kit by Manmohan Pal https://www.youtube.com/watch?v=rcaQluS7Gzw
RF Remote Control Circuit Using 433 Mhz Module and HT12E Encoder and HT12D Decoder IC by Manmohan https://www.youtube.com/watch?v=51TNQiaXm3U
IC L293 Moter Driver H Bridge IC by Manmohan Pal https://www.youtube.com/watch?v=1Gh-aVm5rDg
Wireless 4 Channel 433 Mhz RF Remote Control Transmitter and Receiver Unboxing by Manmohan Pal https://www.youtube.com/watch?v=ZFjDGuFBMnI
433 Mhz RF Module Tx and Rx with Arduino Nano, RF Remote Control Circuit by Manmohan Pal https://www.youtube.com/watch?v=JHN7kgguCG8
RF 4 Channel Remote Control Relay Module using 433 Mhz RF Transmitter and Reciever bu Manmohan Pal https://www.youtube.com/watch?v=1bgBXruwxfE&t=58s https://www.youtube.com/watch?v=C1qGVaGgGOo
Touch Switch using NAND gate IC 4011 by Manmohan Pal https://www.youtube.com/watch?v=jIEKWVs8d40
Touch Switch || Toggle aswitch || Touch ON Touch Off Switch using IC 4017 https://www.youtube.com/watch?v=9iA0AtnrL7A
433 Mhz RF Module Tx and Rx with Arduino Nano, RF Remote Control Circuit by Manmohan Pal https://www.youtube.com/watch?v=JHN7kgguCG8&t=607s
Remote Control Relay Module 4 Channel 5 volt by Manmohan Pal https://www.youtube.com/watch?v=67_CzDsuyfw
Remote control for every home appliance https://www.youtube.com/watch?v=mUuSYWyD7Ic
Remote operated light- by Manmohan Pal https://www.youtube.com/watch?v=5oP1SCkVJm8
Remote control Fan- IR remote control Circuit using IC 555 Timer by Manmohan Pal https://www.youtube.com/watch?v=GvAZadfdIAE
Arduino Nano Unboxing| Uploading First Program on Arduino Nano- By Manmohan Pal https://www.youtube.com/watch?v=OxQcPwc8Wl0
