Introduction: Digital Termometer
Hi everybody this is my first instructables , and it's a digital termometer using a IC2 display ,an Arduino UNO, a rechargable battery(a powerbank),a LM35 as the temperature sensor, and a pushbutton wich if you pushes it it displays temperature rather on celsius or farenheit.
The Arduino and the display i bought them on Ebay.
The display was around 8usd.
The LM35 you can get it at any electronics shop, for no more than 1usd.
I used the liquidCrystal_I2C library and the wire.h.
Here is the programming:
#include <Wire.h>
#include <LiquidCrystal_I2C.h> //libraries
int termo=A0;
int boton=5;
int estadoboton=0;
LiquidCrystal_I2C lcd(0x27,16,2);
void setup()
pinMode(boton,INPUT);
lcd.init(); // initialize the lcd
Serial.begin(9600);
lcd.print("TEMPERATURA");
lcd.backlight();//enciendo la luz del LDC
delay(250);
lcd.noBacklight();//apago la luz del LCD
delay(250);
lcd.backlight();
void loop()
estadoboton=digitalRead(boton);
if (Serial.available()) {
delay(100);
lcd.clear();
while (Serial.available() > 0) {
lcd.write(Serial.read());
if(estadoboton ==HIGH){
float temperatura=analogRead(termo);
float tempF=((((temperatura*500)/1024)*1.8)+32);
Serial.print("Temperatura");
Serial.println(tempF);
lcd.setCursor(11,0);
lcd.print(tempF);
lcd.setCursor(1,1);
lcd.print("Farenheit");
delay(500);
if(estadoboton==LOW){
float tempC=((temperatura*500)/1024);
Serial.println(tempC);
lcd.print(tempC);
lcd.setCursor(1,1);
lcd.print("Celsius ");
delay(500);
#include <Wire.h>
int termo=A0;
int boton=5;
int estadoboton=0;
void setup()
Serial.begin(9600);
delay(250);
delay(250);
lcd.backlight();
void loop()
delay(100);
lcd.clear();
lcd.print(tempF);
lcd.setCursor(1,1);
delay(500);
lcd.print(tempC);
lcd.setCursor(1,1);
delay(500);
