Introduction: Arduino Powered Digital Thermometer
This is a digital temperature measurement device powered by the Arduino UNO R3. It is quite simple and a very handy thing to be able to make. A suitable project to learn about Liquid Crystal Displays (LCDs) interacting with an Arduino.
Step 1: Gather the Components Needed
For this project you will need:
- An Arduino with USB connectivity
- 220 ohm resistor
- 10K Potentiometer
- Arduino-compatible 16 x 2 LCD
- Temperature sensor
- Breadboard and wires
Step 2: Get Power
To give your breadboard power, connect the 5v and GND pins on your arduino to the + and - on the side of the breadboard respectively.
Step 3: Wire Up the Temperature Sensor
Connect the left pin on the flat side of the temperature sensor to +. The centre pin of the temperature sensor goes to A0 (Analog Input 0). And the right pin on the flat side of the temperature sensor goes to -. The temperature sensor is now active.
Step 4: Wire Up the LCD and Potentiometer
To make explaining a lot easier, use this diagram to wire up the LCD and potentiometer. The potentiometer will control the brightness/contrast of the LCD.
Step 5: Program
This is the code I wrote. Feel free to copy.
