Introduction: Digital Water Level Meter With Arduino
this tutorial shows you how to make a digital water level meter with arduino and color display
Step 1: Parts
*Any arduino board
*ili9341 tft display
*5 x 2.2k resistors ,5 x 3.3k resistors
*ultrasonic sensor
Step 2: Connection
Connect display to arduino as above.
resisters are used to convert 5v logic to 3.3. because ili9341 is only working with 3.3v signals.
otherwise whole screen will be filled with white.
*ultra sonic
Trig pin > Arduino pin 5
Echo pin > Arduino pin 6
Step 3: Code
upload this code - and change above mention lines if necessary
or copy this
#include // include Adafruit graphics library
#include // include Adafruit ILI9341 TFT library
const int trigPin = 5; const int echoPin = 6; // defines variables long duration; int distance; int presntage=0; #define TFT_CS 8 // TFT CS pin is connected to arduino pin 8 #define TFT_RST 9 // TFT RST pin is connected to arduino pin 9 #define TFT_DC 10 // TFT DC pin is connected to arduino pin 10 // initialize ILI9341 TFT library Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC, TFT_RST);
int home; void setup() {
pinMode(trigPin, OUTPUT); // Sets the trigPin as an Output pinMode(echoPin, INPUT); Serial.begin(9600); Serial.println("ILI9341 Test!"); tft.begin(); // read diagnostics (optional but can help debug problems) uint8_t x = tft.readcommand8(ILI9341_RDMODE); Serial.print("Display Power Mode: 0x"); Serial.println(x, HEX); x = tft.readcommand8(ILI9341_RDMADCTL); Serial.print("MADCTL Mode: 0x"); Serial.println(x, HEX); x = tft.readcommand8(ILI9341_RDPIXFMT); Serial.print("Pixel Format: 0x"); Serial.println(x, HEX); x = tft.readcommand8(ILI9341_RDIMGFMT); Serial.print("Image Format: 0x"); Serial.println(x, HEX); x = tft.readcommand8(ILI9341_RDSELFDIAG); Serial.print("Self Diagnostic: 0x"); Serial.println(x, HEX);
pinMode(2,INPUT); Serial.println(F("Done!"));
int home=0; } void loop(void) {
testText();
delay(4000); waterlevel(); delay(4000);
} void testFillScreen() { unsigned long start = micros(); tft.fillScreen(ILI9341_BLACK); tft.fillScreen(ILI9341_RED); tft.fillScreen(ILI9341_GREEN); tft.fillScreen(ILI9341_BLUE); tft.fillScreen(ILI9341_BLACK); }
void waterlevel() { tft.fillScreen(ILI9341_BLACK);
tft.drawRect(18,18, 84, 284,ILI9341_GREEN);
while(true) { digitalWrite(trigPin, LOW); delayMicroseconds(2); // Sets the trigPin on HIGH state for 10 micro seconds digitalWrite(trigPin, HIGH); delayMicroseconds(10); digitalWrite(trigPin, LOW); // Reads the echoPin, returns the sound wave travel time in microseconds duration = pulseIn(echoPin, HIGH); // Calculating the distance distance= duration*0.034/2; // Prints the distance on the Serial Monitor Serial.println(distance);
if(distance<6) {distance=0;} distance=distance-5; if(distance<0) {distance=0;}
if(distance>130) //put here height of your water tank. {distance=130; //put the above value if change, here also }
presntage=distance*100/130; //replace 130 with your water tank height. presntage=100-presntage;
tft.setCursor(130, 130); tft.fillRect(120,120, 120, 50,ILI9341_BLACK); tft.fillRect(20,20, 80, 280,ILI9341_BLACK); tft.setTextColor(ILI9341_GREEN); tft.setTextSize(4); if(presntage!=100){ tft.print(presntage);tft.print(" %"); } else { tft.print(presntage); } if(presntage<10) { tft.fillRect(20,20+(100-presntage)*2.8, 80, presntage*2.8,ILI9341_RED); } else if(presntage<30) { tft.fillRect(20,20+(100-presntage)*2.8, 80, presntage*2.8,ILI9341_YELLOW); } else if(presntage<80) { tft.fillRect(20,20+(100-presntage)*2.8, 80, presntage*2.8,ILI9341_BLUE); } else { tft.fillRect(20,20+(100-presntage)*2.8, 80, presntage*2.8,ILI9341_GREEN); }
delay(1000); }
} void testText() { tft.fillScreen(ILI9341_BLACK); tft.setCursor(20, 40); tft.setTextColor(ILI9341_WHITE); tft.setTextSize(5); tft.println("Welcome");
tft.setCursor(30, 140); tft.setTextColor(ILI9341_RED); tft.setTextSize(2); tft.println("Press Buttons");
tft.setCursor(40, 160); tft.setTextColor(ILI9341_GREEN); tft.setTextSize(2); tft.println("To Navigate");
tft.fillRect(0,290, 100, 30,ILI9341_YELLOW);
tft.setCursor(10, 300); tft.setTextColor(ILI9341_BLUE); tft.setTextSize(2); tft.println("W.Level"); tft.fillRect(140,290, 100, 30,ILI9341_BLUE); tft.setCursor(150, 300); tft.setTextColor(ILI9341_BLACK); tft.setTextSize(2); tft.println(" Info");
