Introduction: Digital Camoflage (digicamo)
This is a guide on how to digicamo your airsoft rifle, real rifle, or anything you want.
Step 1: Object
Find the object you are going to camoflage. I am doing an airsoft sniper rifle.
Step 2: Materials
Get the materials you will need:
Matte (not shiny) paint-1 base color, 3 stencil colors(you can use as many as you like, i used 3). I used Rust-oleum paints: tan, black, brown, and green.
Masking/painting tape
a method for hanging the objects to be painted
paper
exacto knife
rubber glove
optional: Minwax Fast drying polyurethane for the finish
paper
exacto knife
rubber glove
Step 3: Dissasembly
Disassemble the rifle and keep the parts you are going to paint. You don't want to paint the compression chamber or the rubber stock cover.
Step 4: Taping
Tape off all areas you don't want paint in with the masking tape. Don't be lazy on this part. You don't want paint in your barrel or on your scope lens.
Step 5: Base Coat
Hang the parts up and paint them with the base coat. My base color was tan. Follow the instructions on the spray paint for number of coats and dry times. i did 3 coats.
Step 6: Stencils
This is the tedious part. Print out the patterns you desire from http://tacticalcamo.com/MARPAT/digi.php
You want large and small cutouts; more black and less black.
On the third picture in this step are all the stencils i ended up with.
Step 7: Cutting Out the Stencils
Take a pattern paper and clamp it down on a piece of wood. Then get an exacto knife and cut out the black parts.
Step 8: First Color
Now you paint the first color. Mine was green. You want the stencils of the bottom color to be the biggest. Hold the stencil over the gun, cover the other exposed parts with paper. Wear gloves unless you want your hand colored.
Step 9: Other Colors
After you are done with green move on to the second color, brown. Then do the black. The stencils should get progressively smaller. Do all the parts of the gun. Beware the circular parts are the hardest like the barrel and the scope and you will have to find some creative ways to hold the stencil down.
Step 10: Protective Finish
This step is optional but i recomend it because the paint scratches off easily. Disassemble and coat the rifle with Minwax Fast drying polyurethane. I used 5 coats on everything. It makes the gun a little shiny but it feels much better.
Step 11: Last Step
Remove all the tape and reassemble.
