Large Silhouette Chandelier Decoration, the Grandelier
Intro: Large Silhouette Chandelier Decoration, the Grandelier
As a creative freelancer, I often design themed environments for special events. Large chandeliers are expensive (even as a rental) and are exceedingly complicated to transport or assemble. I developed this solution which creates a nearly six ft. wide , visually-substantial chandelier that weighs less than 13 lbs, and packs flat, and at only half the diameter! I liked the simple lines of chandeliers I'd seen in used in modern designs seen in urban lounges and hotels. This versatile chandelier can even be electrified fairly easily. These are primarily popular in white or black, but can be cut from other routable board products such as PVC plastic sheet or even acrylic.
These instructions will help you create my initial chandelier design.
I've developed an updated and improved version which is manufactured from PVC plastic sheet and includes battery-operated LED candles. I've called it the Grandelier. It's also now available in two sizes.
Purchase a ready-to-assemble chandelier at Grandelier.com
Now also available in a 28" wide Petit size!
STEP 1:
You will then need to have access to a CNC router. I don't have one of my own, but use a local service, which also supplied the Gatorboard foam board which I've chosen to use for it's cost, relatively good durability and especially how light weight it is.
You will need six sections of half of the chandelier. All halves are identical. To make my chandeliers as large as possible, I was able to get two on a standard 48" x 96" sheet, so I required three sheets total to be cut.
In my builds, I've used 1/4" Gatorboard foam board, and the slots in the design are cut to accomodate that thickness. Each chandelier requires four slotted disks to hold each of the six sections into place. The slots are 1/2 the radius of the disk, with four matching slots on each chandelier section. Though I require only four of these disks per chandelier, I have plenty of spare room on my 4x8 sheet to cut extra, which is always a great idea to have spares!
Additionally, I have teardrop "crystals" cut and pre-drilled to be strung with loops of monofilament and hung from the two tiers of each chandelier section.
STEP 2:
Starting with one section, attach all four of the slotted disks to it. Then, one at a time add each additional adjacent chandelier section until they are all connected. This next part is where an assistant can really help. While all of the chandelier sections are held together around the center, run a zip tie around near the top, and the bottom, pulling it secure, but not enough to damage the foam board. A third zip tie may be added in the middle, but I have never found it necessary.
Pre-measure and cut lengths of monofilament to loop through each of the teardrop cutouts. When these are strung and tied off, hang one from each of the two tiers of all six chandelier sections (twelve total).
Your chandelier is fully assembled! To hang it, create a loop of monofilament around the upper most zip tie one two opposing sides and you will be able to hang it level.
To enhance your chandelier with actual illumination see the following step.
STEP 3:
Though you can make substitutions, here is what I used:
18/2 gauge lamp cord
snap-on C9 light bulb sockets from Action Lighting: http://www.actionlighting.com/c9-socket-spt2-white-100-bag-bag/
1" diameter thin wall PVC or cardboard tube
First, using a utility knife, cut all of the candle and flame-bulb silhouettes, unless of course you altered the design to not include them in the first place!
Then cut twelve 4-5 inch section of the 1" tube to act as the candles. Cut a roughly 1" deep notch through the tubing in order to secure them in place on the foam board silhouette. Hot glue can permanently secure them easily. Cut an additional notch on the opposite end of the tube, perpendicular to the first to allow the lamp cord and socket to properly seat.
Using the snap on light sockets, attach one and slide it into one of the tube "candles". loosely drape the lamp cord to the adjacent candle and add another socket. Continue working around the lower level, then up and around the upper level ending the wiring up at the center of the chandelier leaving as much of a tail as required. Add the plug of your choice.
The wiring "disappears" for the most part, but additional teardrop shapes can be hung from the wiring if desired.
23 Comments
V1v0 6 years ago
Beautiful!!! Need to make for Prom decorations. Trying to figure out the size, I think the ceiling is 15 feet? Can I modify and just make it with 4 sides instead of the 6? I'll be using foam core 20x30. Thank You in advance for any assistance!!!
davidandora 6 years ago
Thank you. The only modification you'll need to make for a 4 section chandelier are to the central slotted disks, which would only require 4 slots in a cross formation. You can certainly scale this to any size you like, but you should be sure that the slots on both the chandelier sections and the disks are just slightly thinner than your foam core for a good fit. Good luck! :)
Dawsie 7 years ago
I love the chandeliers they look awesome I just wish I had the space to put one up ? If I ever do I have bookmarked this for just in case but if my oak tree grows tall enough I just might make one to go on it just to be different lol
Thanks formbe generaus and supplying the picture with the instructable as I live in the middle of now where I don't have access to a CNC machine so I will have to make do with my scrol saw lol
KarlaL6 7 years ago
Thanks a lot!
SheilaShaikh 9 years ago
Omg, that is awesome! can you please start selling these!?
davidandora 9 years ago
www.grandelier.com
viajante 11 years ago
davidandora 11 years ago
bagnitsch 12 years ago
davidandora 12 years ago
canucksgirl 12 years ago
Cheyannelovesham 12 years ago
EllieRose 12 years ago
Organize74 12 years ago
porklips 12 years ago
