Introduction: Dining Table 2
We had the opportunity to make another dining table in order to satisfy a good friend’s request to create one for him by giving us a very beautiful piece of wood. The particular piece of wood has an irregular shape as it is a horizontal slice taken by an IROKO tree. Not only its irregular shape but also the shades of the internal tree bark make the surface of our wooden table look incredibly beautiful.
Step 1: Metallic Frames
Measuring the width from the edges of the wooden piece, we made two metallic frames of 68cm height and their width is equal to the wooden surface. For the making of this metallic framework, we used a blade of 10mm thickness and 10cm width. These two frames were connected with a metallic blade in order to have a stable base as well as a stable table. Therefore, we punctured the metallic frames in various points besides the central point so that when the wood would be screwed the table would become much more stable. The width of the table is about 85cm and its length is 240cm while its height is 75cm.
Moreover, under the metallic points that touch the ground, we placed soft floor mats in order to avoid damaging the table or the floor by its use. The final touch of our metallic framework was made after we had painted all the metallic points with wheat and then with lead.
Step 2: Rubbed
After we had perfectly rubbed the whole wooden surface with a belt sander, then with an orbit sander and afterwards with a finishing sander with sandpapers of 40 grit, 160 grit and 240 grit, we managed to have a very smooth surface that was painted with satin varnish twice.
In conclusion, combining the framework in mat lead colour with the satin varnish that was used to paint the wood, we have reached an outstanding outcome. Finally, another great touch on our table is our logo that was made with our handmade pyrographer, which electrically heats the logo of the ‘make it extreme’ team and shapes it on the surface in a magical way!
