Introduction: Dinosaur Game Hack Google Chrome Games
chrome t-rex run is a very fun game. Here we are going to make it more entertaining by using Arduino. This dino game will appear on no internet connection page.You can also do this using raspberry pi here we compare both the boards in detail Arduino vs Raspberry pi. check this article to chose to write board.
Arduino UNO
LDR (light dependent resistor)
10k ohm resistor
Servo motor
Jumper wires
breadboard
USB Cable
Google chrome on a PC
Step 1: Connection
Connect every Component according to the circuit diagram or follow the below table.
Arduino Pin no.---------A0------------------9-------------------GND-----------------Vcc----
LDR------------------------First leg-------------*---------------------*-------------------second leg
Servo motor------------------*----------------yellow wire--------Brown wire-----------Red wire
10k ohm Resistor----------First Leg-----------*--------------------Second wire---------------*---------
Connect everything according to the circuit diagram. Also, use pull-down (explain in this article)
resistance.
Step 2: LDR
LDR () also known as a photoconductor. It is basically a photocell that
works on photoconductivity. This is basically a resistor whose value is decrease when the intensity of light is decreases. This component is use in Street light, Camera, Light beam alarm, etc.
Step 3: Structure and Working
Dinosaur Game Hack Google chrome games
By sanjeev May 3, 2020 Arduino Projects, HOME 0 Comments
Spread the love
No internet dinosaur game (Trex run) is a fun game. This dino game will appear on no internet connection page. The second method to open this game is to put your device on Flight mode and open google chrome. Keep pressing the space bar again and again and let Trex jump to save from the cactus plant is become a boring task. Let’s try a new way to do this. Here we will make Dinosaur Game Hack in a totally different way.
Contents [hide] 1 Material Required 2 LDR (Light-dependent resistor)2.1 About LDR2.2 Structure and working2.3 LDR Connection with Arduino2.3.1 Software2.3.2 Hardware3 Servo motor3.1 Servo motor Arduino4 Final Connection5 Installation on Computer5.1 Step:- 15.2 Step:- 25.3 Step:- 36 Coding for Trex run7 Final code copy and upload on your Arduino board
Material Required
Arduino UNOLDR (light dependent resistor)10k ohm resistor serve motorJumper wiresbreadboardUSB Cable Google chrome on a PC for Dinosaur Game Hack
About LDR
LDR () also known as a photoconductor. It is basically a photocell that works on photoconductivity. This is basically a resistor whose value is decreased when the intensity of light is decreased. This the component is used in Street light, Camera, Light beam alarm, etc.
LDR Working
The main component for the LDR is cadmium sulfide (CdS), which is used as the photoconductor and contains very few electrons when not illuminated. As soon as light falls on the sensor, the electrons are liberated and the conductivity of the material increases. When the light intensity exceeds a certain frequency, the photons absorbed by the semiconductor give band electrons the energy required to jump into the conduction band. This causes the free electrons or holes to conduct electricity and thus dropping the resistance dramatically (< 1 Kiloohm).
R = A.E^a
where E – Illumination (lux) R – Resistance (Ohms) A, a – constants
Step 4: Servo Motor
A servo motor is a close loop system, that allows for precise control of
angular position. It has 3 wires system red, brown and yellow for supply, GND, and signal.
Step 5: Installation
With the help of a tape stick LDR facing toward screen leaving 1cm space from Dino Google.
Step 6:
With the help of tape stick Servo motor near space bar, Such a way the shaft of motor hit the space bar.
Step 7:
The final output will be like this.
Step 8: Code
Copy-paste code in Arduino IDE verifies and upload the code.
Step 9: Nextpcb
I use my own designed Arduino provided by nextpcb . also you can get custom shape size and color PCB which make your project more attractive. I suggest check now and get amaxzing benifits like welcome bonus and many more things.
