Introduction: Dirt Cheap Home Theater
-AFTER A YEAR OF INACTIVITY I'M BACK-
Have you ever wanted to watch a video on your phone but couldn't because holding it makes your arm tired? Well, make this cardboard home theater! It doesn't cost much to make at all, and you can lay down and watch your favorite GreatScott videos!
Step 1: The Box
Get a box at least 12 by 12 by 12 inches.
Or, if you don't feel like measuring, get a box you can do this with:
Step 2: Other Tools
Pretty straightforward. You need a sharpie, a razor, duck tape, and scissors
Step 3: Cut Flaps Off of Box
Pick a side and cut the flaps off of the cardboard box. This is so that you can put your head in and watch.
The box doesn't have to be perfectly cut, but it should be so that you can watch without any light coming in from the bottom
Step 4: Measure Out Your Phone
I have an iPhone 6, and the screen is about 4.2 by 2.4 inches (give or take). However, if you don't use an iPhone 6, measure your screen with a ruler and mark it on the box. Then, cut the hole using the box razor. Do this carefully, as you'd want the hole to exactly fit the size of your screen
Step 5: Measure Out Your Neck
Ok, the steps are kinda weird but they work
1) use your hand and grab your neck to measure out the length and width of your neck.
2) After measuring length and width, mark them on the box horizontally and vertically (look at pics)
3) make an oval with the measurements on your hand using the sharpie
4) cut out the oval thing and test it on your neck. I had to adjust the length of the oval because of my darn adams apple
5) use duck tape to prevent any cardboard chafing
Step 6: The Annoying Inner Flaps
Use duck tape to keep these little buggers out of the way
Step 7: I Had To...
Gotta keep the projects in the MLP theme guys. Can't be inconsistent with the title of my instructables :)
Step 8: Enjoy Ur Box
Congrats! you went from having a box to having a box with an elliptical and rectangular hole cut in it! Use it to watch videos all day long and pretend your mom isn't hovering above you wondering why you didn't take out the the trash!
Kudos to keets for mentioning this: you may need to poke some air holes with your razor blade if you have trouble breathing. I don't have a problem, but I'm not everyone. Thanks keets :)
