Introduction: Disassembling Western Digital MyBook World Edition
Ever complain that the fan in the MyBook World Edition is too loud or the drive is transferring too slow that you want to remove the hard drives to put in external USB hard drive case? If you answered yes to either questions or both, I will show you how to disassemble your MyBook World Edition to disconnect the power cable to the fan and to remove the hard drives.
Please note that this may void your WD warranty. But if it's past your warranty or you simply do not care about your warranty, then proceed.
Please also note that disconnecting the fan may risk the device overheating. Upon disconnecting the fan, please place hard drive in a well ventilated area.
Step 1: Tool You Will Need
All you need is a standard Philips head screwdriver. To disconnect the fan you may need a smaller screwdriver since it requires prying a connector loose from a small access hole. Sounds tricky but not difficult.
Remove all four screws on the outside case with Philips head screwdriver.
Step 2: Remove the Plastic Case
Carefully push the plastic piece that acts as a vent hole out. It may require rotating the device and pushing from both sides.
It should slide out like the picture shown.
Step 3: Unscrew the Metal Cover
When the plastic cover is removed, you should see a metal cover that has Drive A and Drive B written on it. Unscrew the screw that is holding the piece as shown in the picture. The screw is not removable, so just make sure it's fully unscrewed.
Step 4: Removing the Metal Cover
Position the head of your screwdriver over one of the blue plastic pieces and give it a push. The cover should slide and there should be a gap where the screw was holding the metal cover before.
Simply lift up the metal cover to remove it.
Step 5: Unplug Hard Drive
You now have access to the hard drive. Simply unplug the cables to the hard drive, bend the blue plastic piece in, and lift. The hard drive should come out pretty easily.
Have fun!
The remaining instruction is for disconnecting the fan. You will need to remove both hard drives.
Step 6: Removing the Fan
This step is a bit tricky and you will need a smaller screwdriver.
Follow the red and black wires from the fan into the case. I never bothered with trying to open up the rest. Rotate the case and try to look into where the hard drives were placed. You should see a white three-pin connector. Simply disconnect that and that should disconnect the fan.
If you're reading this step, I'm assuming you just wanted to disconnect the fan and will want to put the device back together.
Simply put the hard drive back in the order it was removed, connect the cables back on, slide back the metal cover (make sure the blue plastic piece on the hard drive sticks out from the metal cover), screw the metal cover back on, slide the plastic vent piece back in and re-attach the four screws from earlier.
6 Comments
11 years ago
This is a great Instructable, but you need to add a main image of the final project to the intro step. Please do that and leave me a message when you have so that we can publish your work. Thanks!
9 years ago on Introduction
Thanks. I have the WD model world book with the firewire and usb and this instructable was right on the money. Thanks.
10 years ago on Introduction
Great tutorial. However I have the 1tb my book world nas with the blue rings and it does not have any screws to remove on the outside.
Is there a tutorial for my NAS drive?
11 years ago on Step 1
What if the MyBook does not have screws like mine?
Reply 11 years ago on Step 1
Actually, this might be what you are looking for: http://www.instructables.com/id/How-to-Open-a-Western-Digital-MyBook-USB-Drive./
Unfortunately, this is primarily written for the MyBook World Edition with ethernet -- network attached storage (NAS) -- and not for the MyBook USB/Firewire version.
You will need to do a search for specifically MyBook.
My suggestion would be to search for "MyBook USB" or "MyBook Firewire" depending on your MyBook type.
Hope this helps!
